关于ESP8266作为AP的问题[Done]
pwwzlxz
Postby pwwzlxz » Wed Jun 01, 2016 9:36 pm
ESP8266设置为station+ap模式,手机可以连接AP,但是PC连接AP时连接不上,通过串口输出的信息看应该是PC反复连接,断开AP(ESP8266),请问是哪里出现问题?
我的代码如下:
#include "esp_common.h"
#include "uart.h"
#include "freertos/task.h"
extern void vTask_ap( void * pvParameters );
extern void vTask_station( void * pvParameters );
void user_init(void)
xTaskHandle xHandle = NULL;
uart_init_new();
if(wifi_set_opmode_current(0x03) == 0)
printf("wifi set mode 0x03 failed!\r\n");
while(1);
printf("wifi set mode 0x03 success!\r\n");
xTaskCreate(
vTask_ap, /* Function that implements the task. */
"ap_task", /* Text name for the task. */
512, /* Stack size in words, not bytes. */
NULL, /* Parameter passed into the task. */
1,/* Priority at which the task is created. */
&xHandle ); /* Used to pass out the created task's handle. */
xTaskCreate(
vTask_station, /* Function that implements the task. */
"station_task", /* Text name for the task. */
while(1)
//printf("task_station\r\n");
vTaskDelay(2);
void wifi_handle_event_cb(System_Event_t *evt)
printf("event %x\n", evt->event_id);
switch (evt->event_id) {
case EVENT_STAMODE_CONNECTED:
printf("connect to ssid %s, channel %d\n",
evt->event_info.connected.ssid,
evt->event_info.connected.channel);
break;
case EVENT_STAMODE_DISCONNECTED:
printf("disconnect from ssid %s, reason %d\n",
evt->event_info.disconnected.ssid,
evt->event_info.disconnected.reason);
break;
case EVENT_STAMODE_AUTHMODE_CHANGE:
printf("mode: %d -> %d\n",
evt->event_info.auth_change.old_mode,
evt->event_info.auth_change.new_mode);
break;
case EVENT_STAMODE_GOT_IP:
printf("ip:" IPSTR ",mask:" IPSTR ",gw:" IPSTR,
IP2STR(&evt->event_info.got_ip.ip),
IP2STR(&evt->event_info.got_ip.mask),
IP2STR(&evt->event_info.got_ip.gw));
printf("\n");
break;
case EVENT_SOFTAPMODE_STACONNECTED:
printf("station: " MACSTR "join, AID = %d\n",
MAC2STR(evt->event_info.sta_connected.mac),
evt->event_info.sta_connected.aid);
break;
case EVENT_SOFTAPMODE_STADISCONNECTED:
printf("station: " MACSTR "leave, AID = %d\n",
MAC2STR(evt->event_info.sta_disconnected.mac),
evt->event_info.sta_disconnected.aid);
break;
default:
break;
struct station_info * station;
struct softap_config *config = (struct softap_config *)zalloc(sizeof(struct softap_config)); // initialization
wifi_set_event_handler_cb(wifi_handle_event_cb);
wifi_softap_get_config(config); // Get soft-AP config first.
sprintf(config->ssid, "test");
sprintf(config->password, "11111111");
config->authmode = AUTH_WPA_WPA2_PSK;
config->ssid_len = 0; // or its actual SSID length
config->max_connection = 2;
wifi_softap_set_config(config); // Set ESP8266 soft-AP config
free(config);
while(1)
//station = wifi_softap_get_station_info();
//while(station)
//printf("bssid:%s\r\nip:%s\r\n",MAC2STR(station->bssid), IP2STR(&station->ip));
//station = STAILQ_NEXT(station, next);
//wifi_softap_free_station_info(); // Free it by calling functions
//printf("task_ap\r\n");
vTaskDelay(2);
输出调试信息如下:
SDK version:1.4.0(c599790)
mode : sta(5c:cf:7f:12:67:b1) + softAP(5e:cf:7f:12:67:b1)
add if0
add if1
bcn 100
event 8
event 8
event 8
event 8
event 8
event 8
event 8
add 1
aid 1
station: 3c:46:d8:3a:6d:16 join, AID = 1
event 6
station: 3c:46:d8:3a:6d:16join, AID = 1
station: 3c:46:d8:3a:6d:16 leave, AID = 1
rm 1
event 7
station: 3c:46:d8:3a:6d:16leave, AID = 1
add 1
aid 1
event 6
event 8
event 8
rm 1
event 7
add 1
aid 1
event 6
event 8
rm 1
event 7
add 1
aid 1
event 6
Re: 关于ESP8266作为AP的问题
Postby ESP_Faye » Mon Jun 06, 2016 5:30 pm
您好,
我们测试了您的代码,抱歉未能复现到您的问题。
或者您可以用 WiFi 分析仪,测试信号强度。
