RTOS SDK cannot start timer from interrupt handler
gustavo
Postby gustavo » Thu Jun 02, 2016 11:08 pm
I'm trying to implement debounce when the user clicks a button.
I need to start the debounce timer from within the gpio interrupt. However this leads to a crash.
My code is as follows.
#include "gpio.h"
#include "esp_common.h"
#include "esp_timer.h"
static os_timer_t some_timer;
static void timer_handler(void* args) {
    printf("timer");
static void intr_handler() {
    portENTER_CRITICAL();
    os_timer_disarm(&some_timer);
    os_timer_setfn(&some_timer, (os_timer_func_t *)timer_handler, NULL);
    os_timer_arm(&some_timer, 3, 1);
    portEXIT_CRITICAL();
void user_init(void)
    GPIO_ConfigTypeDef gpio_in_cfg12;
    gpio_in_cfg12.GPIO_Pin  = GPIO_Pin_12;
    gpio_in_cfg12.GPIO_IntrType = GPIO_PIN_INTR_NEGEDGE;
    gpio_in_cfg12.GPIO_Mode = GPIO_Mode_Input;
    gpio_in_cfg12.GPIO_Pullup = GPIO_PullUp_EN;
    gpio_config(&gpio_in_cfg12);
    gpio_intr_handler_register(intr_handler, NULL);
    _xt_isr_unmask(1 << ETS_GPIO_INUM);
The only output I get is:
ShowCritical:1
Edit: If I start the timer from user_init, everything works as planned.
Re: RTOS SDK cannot start timer from interrupt handler
Postby ESP_Faye » Tue Jun 07, 2016 7:40 pm
Please try this
#include "gpio.h"
    printf("timer");
    u32 gpio_status = GPIO_REG_READ(GPIO_STATUS_ADDRESS);
    gpio_pin_intr_state_set(GPIO_ID_PIN(12) , GPIO_PIN_INTR_DISABLE);
    GPIO_REG_WRITE(GPIO_STATUS_W1TC_ADDRESS, gpio_status & BIT(12) );
    //printf("a,");
    //printf("b,");
    //printf("c,");
    //printf("d\n");
        gpio_pin_intr_state_set(GPIO_ID_PIN(12) ,GPIO_PIN_INTR_NEGEDGE);
gustavo
Postby gustavo » Wed Jun 08, 2016 7:05 pm
Shoudn't portENTER_CRITICAL() disable interrupts?
Either way, your code works.
Postby ESP_Faye » Sun Jun 12, 2016 10:29 am
You need to disable the GPIO interrupt as the sample code we gave.
