Accidentially bought those. I know its not yours but maybe you can try to help me flashing it.
My goal is to use them with arduino and Blynk but I'm Running into errors which it seems are related to old Firmware beeing on the chip.
Hooked it up to my FTDI USB and the Flash Tool could read data (Chip type etc.)
Tried to update but for some reason the progress bar doesn't start moving at all (had it in flash mode I'm pretty sure).
Any Idea what might be wrong?
Please see the Screenshot for my settings (did them based on what Data the tool read from my ESP-14 my chip)
Firmware update ESP-14 - Yes I know!
Re: Firmware update ESP-14 - Yes I know!
Postby Gorkde » Tue Jun 07, 2016 5:49 pm
Ok, just tried again, no luck. It's Syncing but can't write for some reason.
Did order some ESP13 already but they are still on their way from China.
Would like to update this module to be able to continue developing until my other chips arrive. Else I#d have to waste time sitting around waiting.
Anyone could help please? What about the efuse? is this correct or is the Chip write protected?
Something other that's suspicious: The Chip is connected to COM5 (also I did set up the tool for it) but in the log it shows COM6?!
load config ...
EFUSE_MODE: 1
load config ...
test label: Download Panel 1
self.num: 1
init finished
_COM: 6
ESP_ROM_BAUD : 115200
EFUSE_MODE: 1
test baudrate: 115200
test baudrate selection: 4
test label: Download Panel 2
self.num: 2
init finished
_COM: 6
EFUSE_MODE: 1
test baudrate: 46080
test baudrate selection: 2
test label: Download Panel 3
self.num: 3
init finished
_COM: 6
EFUSE_MODE: 1
test baudrate: 9600
test baudrate selection: 0
test label: Download Panel 4
self.num: 4
init finished
_COM: 6
EFUSE_MODE: 1
test baudrate: 9600
test label: Download Panel 5
self.num: 5
init finished
_COM: 6
EFUSE_MODE: 1
test baudrate: 9600
test label: Download Panel 6
self.num: 6
init finished
_COM: 6
EFUSE_MODE: 1
test baudrate: 9600
test label: Download Panel 7
self.num: 7
init finished
_COM: 6
EFUSE_MODE: 1
test baudrate: 9600
test label: Download Panel 8
self.num: 8
init finished
_COM: 6
EFUSE_MODE: 1
test baudrate: 9600
tout as adc
RF option applied...
(True, [])
test running : False
serial port opened
Connecting...
chip sync ok!
0x3ff00050: 7a980000
0x3ff00054: 0200d1c3
0x3ff00058: 5a00b000
0x3ff0005c: 0018fe34
EFUSE MODE : 1
reg0:7a980000
reg1:0200d1c3
reg2:5a00b000
reg3:0018fe34
check_err_0: 0b
check_err_1: 00
check_err_2: 00
check_err_3: 02
check_err_4: 0b
EFUSE NORMAL MODE
CRC IN MODE 1:
crc_calc_res: 90
target crc val: 90
CRC IN MODE 1:
crc_calc_res: 152
target crc val: 152
EFUSE LOG:
EFUSE LOG:
REG0:7A980000
REG1:0200D1C3
REG2:5a00b000
REG3:0018FE34
EFUSE NORMAL MODE
EFUSE CHECK PASS...
reg2>>13: 5
48bit mac
debug:
18 fe 34 d1 c3 7a
ID FOR XM: 05 A0 00 00 00 09 80 00
XM_ID: 05A0000000098000
crc_efuse_4bit: 0
crc_calc_4bit: 9
48bit mac
MAC AP : 1A-FE-34-D1-C3-7A
MAC STA: 18-FE-34-D1-C3-7A
get mac res: True
('tttest uuuuuuuuuuart : uart reg: ', 457)
(' baudrate: ', 115200)
get crystal: 26323200
head: 0 ;total: 0
erase size : 0
get flash id : 0x371440e0
manufacturer_id: 0xe0
device_id: 0x4014
vendor: 224
mode: 64
mode: 0
sel.freq: 26000000
tttttest crystal : 1
com closed
