ESP8266 module reset
beparas
Postby beparas » Tue Jun 07, 2016 5:48 pm
Hi ALL,
I have 2 no. of ESP8266 module. I configure them by using AT command as follows.
Module 1 settings
    AT+CWMODE=3
    AT+CIPAP="192.168.1.0"
    AT+CWSAP="esp_1","",1,0         [Note: for testing no password is set]
    AT+CIPAP?
       +CIPAP:ip:"192.168.1.0"
       +CIPAP:gateway:"192.168.1.0"
        +CIPAP:netmask:"255.255.255.0"
    AT+CWSAP?
       +CWSAP:"esp_1","",1,0,4,0
Module 2 settings
    AT+CWMODE=3
    AT+CIPAP="192.168.2.0"
    AT+CWSAP="esp_2","",1,0         [Note: for testing no password is set]
    AT+CIPAP?
       +CIPAP:ip:"192.168.2.0"
       +CIPAP:gateway:"192.168.2.0"
    AT+CWSAP?
       +CWSAP:"esp_2","",1,0,4,0
Now I want to connect to Module 1 from Module 2, so I send following command from Module 2.
    AT+CWJAP="esp_1",""
      WIFI CONNECTED
      WIFI GOT IP
Connection Ok. no problem.
Now I switch off Module 1, and send above command from module 2, my module 2 got reset with following log
   AT+CWJAP="esp_1",""
         ets Jan  8 2013,rst cause:4, boot mode:(3,7)
        wdt reset
        tail 0
        chksum 0x8d
        tail 12
        chksum 0xcf
        ho 0 tail 12 room 4
        tail 4
        chksum 0xcf
        csum 0xcf
        2nd boot version : 1.2
          SPI Speed      : 40MHz
          SPI Mode       : DIO
          SPI Flash Size : 32Mbit
        jump to run user1
        rlŽô
        ready
Another observation is that.
After above error I restore the setting of Module 2 to factory setting by "AT+RESTORE" command and again configure Module 2 given by above steps.
Now when I fire connect command I got some response, In this case my module is not got reset. (Note: Module 1 is still switch off)
    AT+CWJAP="esp_1",""
    +CWJAP:3
    FAIL
So My question is why module got reset in Test case 1.
What is meaning of "rst cause:4" in error log?
Thanks in advance.
Re: ESP8266 module reset
Postby ESP_Faye » Sun Jun 12, 2016 9:40 am
Did you download the AT bin files into flash using ESP Flash Download Tool, and selecting the corresponding Flash size ?
