[ESP8266] Station mode: Connect to router
Postby ESP_Faye » Fri Feb 27, 2015 4:45 pm
:idea: :idea: :idea:
user_init is the entry of program.
Notice that call
   //need not mac address
   stationConf.bssid_set = 0;
before
Otherwise it may check target AP's MAC address
LOCAL os_timer_t test_timer;
 * FunctionName : user_esp_platform_check_ip
 * Description  : check whether get ip addr or not
 * Parameters   : none
 * Returns      : none
void ICACHE_FLASH_ATTR
user_esp_platform_check_ip(void)
    struct ip_info ipconfig;
   //disarm timer first
    os_timer_disarm(&test_timer);
   //get ip info of ESP8266 station
    if (wifi_station_get_connect_status() == STATION_GOT_IP && ipconfig.ip.addr != 0) {
      os_printf("got ip !!! \r\n");
    } else {
        if ((wifi_station_get_connect_status() == STATION_WRONG_PASSWORD ||
                wifi_station_get_connect_status() == STATION_NO_AP_FOUND ||
                wifi_station_get_connect_status() == STATION_CONNECT_FAIL)) {
         os_printf("connect fail !!! \r\n");
        } else {
           //re-arm timer to check ip
            os_timer_setfn(&test_timer, (os_timer_func_t *)user_esp_platform_check_ip, NULL);
            os_timer_arm(&test_timer, 100, 0);
 * FunctionName : user_set_station_config
 * Description  : set the router info which ESP8266 station will connect to
 * Parameters   : none
 * Returns      : none
user_set_station_config(void)
   // Wifi configuration
   char ssid[32] = SSID;
   char password[64] = PASSWORD;
   os_memset(stationConf.ssid, 0, 32);
   os_memset(stationConf.password, 0, 64);
   //Set ap settings
   //set a timer to check whether got ip from router succeed or not.
 * FunctionName : user_init
 * Parameters   : none
 * Returns      : none
void user_init(void)
   //Set softAP + station mode
   // ESP8266 connect to router.
    user_set_station_config();
