AT+CIPSTART sometimes work but mostly error and AT+RST didnt make the difference
ardiramelan
Postby ardiramelan » Thu Jun 16, 2016 12:44 am
hi
here is my code
AT
AT+RST
WIFI DISCONNECT
tail 4
chksum 0x89
tail 4
chksum 0xe8
tail 8
chksum 0xc0
csum 0xc0
2nd boot version : 1.4(b1)
  SPI Speed      : 40MHz
  SPI Mode       : DIO
jump to run user1 @ 1000
òn't use rtc mem data
rlŽƒrlÌÿ
Ai-Thinker Technology Co.,Ltd.
ready
WIFI CONNECTED
WIFI GOT IP
AT+CIPSTATUS
STATUS:2
AT+CIPSTART="TCP","iot.espressif.cn",8000
ERROR
AT+CIFSR
+CIFSR:APIP,"192.168.4.1"
+CIFSR:APMAC,"1a:fe:34:d6:59:01"
+CIFSR:STAIP,"192.168.43.148"
+CIFSR:STAMAC,"18:fe:34:d6:59:01"
my main problem is :
1. AT+RST, when i tried to reset the module, my wifi is still connected and got ip address from my previous AT+CWJAP instruction. why ? i thought the module will reset and there is no AT command left in there.
2. AT+CIPSTART, always error but sometimes work(only once).
could you please help me ? im really struggling here. thank you
Re: AT+CIPSTART sometimes work but mostly error and AT+RST didnt make the difference
Postby ESP_Faye » Thu Jun 16, 2016 11:59 am
Is there any invisible characters after your command "AT+CIPSTART="TCP","iot.espressif.cn",8000" ?
Any unexpected characters (no matter visible or invisible) will make it to be a wrong command, just as "AT+CIPSTART="TCP","iot.espressif.cn",8000sdfasdfqetwe", and get response "ERROR".
ardiramelan
Postby ardiramelan » Thu Jun 16, 2016 12:10 pm
Espressif_Faye wrote:Hi,
Hi faye thank you for reply.
yes there was a mistake i accidentally put some invisible character(blank space). but after that i get another error response, DNS fail. i tried with other router but it doesn't solve the proble. any suggestions ? thanks
ready
WIFI CONNECTED
WIFI GOT IP
AT+CIFSR
DNS Fail
ERROR
AT+GMR
AT version:0.40.0.0(Aug  8 2015 14:45:58)
SDK version:1.3.0
Build:1.3.0.2 Sep 11 2015 11:48:04
Postby ESP_Faye » Thu Jun 16, 2016 6:14 pm
Could your router access to the internet ?
If your problem is still unsolved, please have a try with our latest AT firmware http://bbs.espressif.com/viewtopic.php?f=46&t=2199.
AT+GMR
SDK version:1.3.0
Please notice that the AT firmware you are using now is not provided by our company, Espressif Systems, so if you change to use our AT firmware, there may be some differences.
