If using espconn in ESP8266_RTOS_SDK, please call espconn_init in user_init as initialization.
Sample code below is based on ESP8266 SDK without OS.
1. Start from user_init
2. Connect to router
3. Connect to cn.bing.com as example
4. Send some HTTP packet..
#include "espconn.h"
#include "mem.h"
#define NET_DOMAIN "cn.bing.com"
#define pheadbuffer "GET / HTTP/1.1\r\nUser-Agent: curl/7.37.0\r\nHost: %s\r\nAccept: */*\r\n\r\n"
#define packet_size (2 * 1024)
LOCAL os_timer_t test_timer;
LOCAL struct espconn user_tcp_conn;
LOCAL struct _esp_tcp user_tcp;
ip_addr_t tcp_server_ip;
* FunctionName : user_tcp_recv_cb
* Description : receive callback.
* Parameters : arg -- Additional argument to pass to the callback function
* Returns : none
LOCAL void ICACHE_FLASH_ATTR
user_tcp_recv_cb(void *arg, char *pusrdata, unsigned short length)
//received some data from tcp connection
os_printf("tcp recv !!! %s \r\n", pusrdata);
* FunctionName : user_tcp_sent_cb
* Description : data sent callback.
* Returns : none
user_tcp_sent_cb(void *arg)
//data sent successfully
os_printf("tcp sent succeed !!! \r\n");
* FunctionName : user_tcp_discon_cb
* Description : disconnect callback.
* Returns : none
user_tcp_discon_cb(void *arg)
//tcp disconnect successfully
os_printf("tcp disconnect succeed !!! \r\n");
* FunctionName : user_esp_platform_sent
* Description : Processing the application data and sending it to the host
* Parameters : pespconn -- the espconn used to connetion with the host
* Returns : none
user_sent_data(struct espconn *pespconn)
char *pbuf = (char *)os_zalloc(packet_size);
os_sprintf(pbuf, pheadbuffer, NET_DOMAIN);
espconn_sent(pespconn, pbuf, os_strlen(pbuf));
os_free(pbuf);
* FunctionName : user_tcp_connect_cb
* Description : A new incoming tcp connection has been connected.
* Returns : none
user_tcp_connect_cb(void *arg)
os_printf("connect succeed !!! \r\n");
espconn_regist_recvcb(pespconn, user_tcp_recv_cb);
espconn_regist_sentcb(pespconn, user_tcp_sent_cb);
espconn_regist_disconcb(pespconn, user_tcp_discon_cb);
user_sent_data(pespconn);
* FunctionName : user_tcp_recon_cb
* Description : reconnect callback, error occured in TCP connection.
* Returns : none
user_tcp_recon_cb(void *arg, sint8 err)
//error occured , tcp connection broke. user can try to reconnect here.
os_printf("reconnect callback, error code %d !!! \r\n",err);
#ifdef DNS_ENABLE
* FunctionName : user_dns_found
* Description : dns found callback
* Parameters : name -- pointer to the name that was looked up.
* ipaddr -- pointer to an ip_addr_t containing the IP address of
* the hostname, or NULL if the name could not be found (or on any
* other error).
* callback_arg -- a user-specified callback argument passed to
* dns_gethostbyname
* Returns : none
user_dns_found(const char *name, ip_addr_t *ipaddr, void *arg)
struct espconn *pespconn = (struct espconn *)arg;
if (ipaddr == NULL)
os_printf("user_dns_found NULL \r\n");
return;
//dns got ip
os_printf("user_dns_found %d.%d.%d.%d \r\n",
*((uint8 *)&ipaddr->addr), *((uint8 *)&ipaddr->addr + 1),
*((uint8 *)&ipaddr->addr + 2), *((uint8 *)&ipaddr->addr + 3));
if (tcp_server_ip.addr == 0 && ipaddr->addr != 0)
// dns succeed, create tcp connection
os_timer_disarm(&test_timer);
tcp_server_ip.addr = ipaddr->addr;
os_memcpy(pespconn->proto.tcp->remote_ip, &ipaddr->addr, 4); // remote ip of tcp server which get by dns
pespconn->proto.tcp->remote_port = 80; // remote port of tcp server
pespconn->proto.tcp->local_port = espconn_port(); //local port of ESP8266
espconn_regist_connectcb(pespconn, user_tcp_connect_cb); // register connect callback
espconn_regist_reconcb(pespconn, user_tcp_recon_cb); // register reconnect callback as error handler
espconn_connect(pespconn); // tcp connect
* FunctionName : user_esp_platform_dns_check_cb
* Description : 1s time callback to check dns found
* Returns : none
user_dns_check_cb(void *arg)
espconn_gethostbyname(pespconn, NET_DOMAIN, &tcp_server_ip, user_dns_found); // recall DNS function
os_timer_arm(&test_timer, 1000, 0);
#endif
* FunctionName : user_check_ip
* Description : check whether get ip addr or not
* Parameters : none
* Returns : none
user_check_ip(void)
struct ip_info ipconfig;
//disarm timer first
//get ip info of ESP8266 station
if (wifi_station_get_connect_status() == STATION_GOT_IP && ipconfig.ip.addr != 0)
os_printf("got ip !!! \r\n");
// Connect to tcp server as NET_DOMAIN
user_tcp_conn.proto.tcp = &user_tcp;
user_tcp_conn.type = ESPCONN_TCP;
user_tcp_conn.state = ESPCONN_NONE;
#ifdef DNS_ENABLE
tcp_server_ip.addr = 0;
espconn_gethostbyname(&user_tcp_conn, NET_DOMAIN, &tcp_server_ip, user_dns_found); // DNS function
os_timer_setfn(&test_timer, (os_timer_func_t *)user_dns_check_cb, &user_tcp_conn);
#else
const char esp_tcp_server_ip[4] = {X, X, X, X}; // remote IP of TCP server
os_memcpy(user_tcp_conn.proto.tcp->remote_ip, esp_tcp_server_ip, 4);
user_tcp_conn.proto.tcp->remote_port = XXXX; // remote port
user_tcp_conn.proto.tcp->local_port = espconn_port(); //local port of ESP8266
espconn_regist_connectcb(&user_tcp_conn, user_tcp_connect_cb); // register connect callback
espconn_regist_reconcb(&user_tcp_conn, user_tcp_recon_cb); // register reconnect callback as error handler
espconn_connect(&user_tcp_conn);
#endif
else
if ((wifi_station_get_connect_status() == STATION_WRONG_PASSWORD ||
wifi_station_get_connect_status() == STATION_NO_AP_FOUND ||
wifi_station_get_connect_status() == STATION_CONNECT_FAIL))
os_printf("connect fail !!! \r\n");
else
//re-arm timer to check ip
os_timer_setfn(&test_timer, (os_timer_func_t *)user_check_ip, NULL);
os_timer_arm(&test_timer, 100, 0);
* FunctionName : user_set_station_config
* Description : set the router info which ESP8266 station will connect to
* Parameters : none
* Returns : none
user_set_station_config(void)
// Wifi configuration
char ssid[32] = SSID;
char password[64] = PASSWORD;
os_memset(stationConf.ssid, 0, 32);
os_memset(stationConf.password, 0, 64);
//need not mac address
stationConf.bssid_set = 0;
//Set ap settings
//set a timer to check whether got ip from router succeed or not.
* FunctionName : user_init
* Parameters : none
* Returns : none
void user_init(void)
//Set softAP + station mode
//ESP8266 connect to router
user_set_station_config();
