DHCP server started message?
FrenkR
Postby FrenkR » Thu Jun 23, 2016 10:50 pm
when setting softAP mode, I am getting a message on debug interface as follows:
mode : softAP(1a:fe:34:d5:a2:9a)
add if1
bcn 100
It looks like DHCP server is somehow autostarted. Is there any way to disable auto-starting or do prevent starting it?
Rgds,
Frenk
Re: DHCP server started message?
Postby ESP_Faye » Fri Jun 24, 2016 4:31 pm
You can call wifi_softap_dhcps_stop in user_init.
FrenkR
Postby FrenkR » Tue Jul 05, 2016 4:02 pm
I have a code like this:
in user_init() I have:
   if (wifi_station_get_auto_connect() != 0)
      wifi_station_set_auto_connect(0);
   // register "init done callback"
   system_init_done_cb(userInitDoneCb);
   // MANDATORY INITIALIZATION BLOCK END
   // disable WiFi
   wifi_set_opmode_current(NULL_MODE);
   // disable DHCP server
   wifi_softap_dhcps_stop();
in "init done callback" I have:
      ETS_UART_INTR_DISABLE();
      _bRes = wifi_set_opmode_current(SOFTAP_MODE);
      ETS_UART_INTR_ENABLE();
      // DHCP is automatically started, so it must be stopped
      wifi_softap_dhcps_stop(); /*
after setting wifi mode, dhcps stop() is called immediately. But message that DHCP is started still appears on debug output, before softAP IP address on if1 is set.
Is there something else missing to prevent autostarting DHCPS?
