[SOLVED] Problem with os_strcat and char-array
Stational
Postby Stational » Mon Jul 04, 2016 7:35 pm
this is my attempt to create a HTTP Get request header:
   char requestText[120];
   strcat(requestText, "GET /myPHP.php?action=insert&value=");
   strcat(requestText, adcValue);
   strcat(requestText, "/ HTTP/1.1\r\nUser-Agent: curl/7.37.0\r\nHost: ");
   strcat(requestText, NET_DOMAIN);
   strcat(requestText, "\r\nAccept: */*\r\n\r\n");
this is what i get if i use
os_printf(requestText);
Ô
@T«GET /myPHP.php?action=insert&value=155/ HTTP/1.1
Host: http://www.myHost.org
Accept: */*
I don't know where these strange chars in front of the 'GET' come from? How do i get rid of them?
tobewinner
Re: Problem with os_strcat and char-array
Postby tobewinner » Tue Jul 05, 2016 10:44 am
Stational wrote:Hello,
Ô
Accept: */*
You should add
memset(requestText, 0, 120);
before strcat
or you can change
to
char requestText[120] = {0};
Stational
Postby Stational » Tue Jul 05, 2016 3:09 pm
Thanks a lot for your answer,
I found out, that this works also very well:
os_sprintf(requestText, "GET /mySQLFunction.php?action=insert&value=%d / HTTP/1.1\r\nUser-Agent: curl/7.37.0\r\nHost: %s\r\nAccept: */*\r\n\r\n",adcRead,NET_DOMAIN);
Postby pratik » Tue Jul 05, 2016 4:52 pm
Hello Stational,
Please explicitly initialize all variables and dynamically allocated memory for reliable code behavior. You still have to follow all the basic rules related to variables in C to avoid compiler specific problems.
