【Feedback】FOTA升级出错
【Feedback】FOTA升级出错
Postby genvy » Tue Jul 05, 2016 11:15 am
串口输出如下,升级失败后重启会失败,Fatal exception这个输出重复很多,
之后一直持续续输出一堆乱码,重启多次依然如此,直到用串口重新刷入。
system_upgrade_start
upgrade_connect 46544
upgrade_connect_cb
pusrdata = HTTP/1.1 200 OK
Server: nginx/1.6.2
Date: Mon, 04 Jul 2016 16:15:16 GMT
Content-Length: 226100
Last-Modified: Mon, 04 Jul 2016 16:06:11 GMT
Connection: close
ETag: "577a8973-37334"
Accept-Ranges: bytes
sumlength = 226100
sec_block 56
........................................................upgrade_get_sum_disconcb 44160
erase sector=1 ok
ets Jan 8 2013,rst cause:4, boot mode:(3,0)
wdt reset
tail 0
chksum 0x63
tail 0
chksum 0x02
tail 0
chksum 0x79
csum 0x79
2nd boot version : 1.5
SPI Speed : 40MHz
SPI Mode : QIO
jump to run user2 @ 81000
Fatal exception (0):
epc1=0x40201a7c, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
upgrade_connect_cb
Server: nginx/1.6.2
Connection: close
sumlength = 226100
sec_block 56
erase sector=1 ok
wdt reset
tail 0
chksum 0x63
tail 0
chksum 0x02
tail 0
chksum 0x79
csum 0x79
SPI Speed : 40MHz
SPI Mode : QIO
Re: 【Feedback】FOTA升级出错
Postby genvy » Tue Jul 05, 2016 5:43 pm
FOTA升级失败的是user1.bin啊,如果user2.bin也烧录失败,为啥升级user1.bin之前的启动可以成功?补充一下升级之前的log
SPI Speed : 40MHz
SPI Mode : QIO
屸滅? ?? #€?r屸茜?傡? !€r屸滅? 廂 ?€lrr?
sleep enable,type: 1
mode : sta(5c:cf:7f:1a:97:71)
add if0
f r0, SDK version:1.5.4(baaeaebb)
ir tx/rx test
Ir tx status machine Clk is hw_timer
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 3
cnt
SPI Speed : 40MHz
SPI Mode : QIO
add if0
ir tx/rx test
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 3
cnt
Postby genvy » Tue Jul 05, 2016 10:29 pm
根据你说的查了一下,结果是40201a7c <user_rf_pre_init+0x528>:
试了一下其他选项,gen_misc最后一步选6=4096KB(1024KB+1024KB)不行,选4=4096KB( 512KB+ 512KB)就正常。
环境如下:
boot_v1.5.bin
ESP8266_NONOS_SDK_V1.5.4_16_05_20
flash_download_tools_v3.3.4_win
应用程序是在nonos_ir_demo基础上修改的。
编译的时候选6,烧录进去后启动日志这样:
SPI Speed : 40MHz
SPI Mode : QIO
貌似选择没有起作用。
是还要做其他修改还是sdk的bug?
环境如下:
boot_v1.5.bin
SPI Speed : 40MHz
SPI Mode : QIO
貌似选择没有起作用。
是还要做其他修改还是sdk的bug?
Postby ESP_Rubin » Wed Jul 06, 2016 11:35 am
这个log很奇怪,不像是6(1024+1024)编译生成的,应该是选择4编译生成的。
另外需要注意,升级文件编译前一定要“make clean”; 升级前后flash map要一致,即user1.bin使用的6编译生成,user2.bin也需要使用6编译
Postby genvy » Wed Jul 06, 2016 2:59 pm
好啊,刷进去之后,esp8266会连接espwifi,密码espwifi123。
在2分钟内telnet端口1112,输入upgrade a.b.c.d:port
esp就会去http://a.b.c.d:port/espup/下载user1.bin或者user2.bin了
我用的模块是ESP-12F
我用的模块是ESP-12F
