Enter Light Sleep Mode cause reset
JacksonLv
Postby JacksonLv » Fri Nov 02, 2018 2:08 pm
I'm trying out to enter light sleep mode in a timer interrupt function,but it will crash and reset as it do sleep sometimes.I found when it is in smart config mode ,it won't crash.If it's in station mode and connected to the AP,it will have this matter.Here is my code and log ,PLS help!! MY SDK version is NONOS 3.0.0
sleep_time_cnt: 60
enter sleep mode
wifi disconnected
pm close 7
fpm open,type:1 0
fpm 758
tail 8
chksum 0xe5
tail 8
chksum 0x84
tail 8
chksum 0xd8
csum 0xd8
   void ICACHE_FLASH_ATTR user_init(){
   PIN_FUNC_SELECT(RED_LIGHT_IO_MUX, RED_LIGHT_IO_FUNC);
   drv_Switch_Init();
   sleep_init();
   os_printf("Firmware Version: 20181101\n");
   wifi_station_get_config_default(&stationConf);
   if (os_strlen(stationConf.ssid) != 0) {
      os_printf("user_scan\n");
      //net_status   = 1;
      os_timer_disarm(&check_ip_timer);
      os_timer_setfn(&check_ip_timer, (os_timer_func_t *) user_check_ip, NULL);
      os_timer_arm(&check_ip_timer, 100, 0);
   } else {
       os_printf("smartcfg\n");
       smartconfig_start(smartconfig_done);
       net_status  = 0;
       WIFI_DISCONNTED_FLAG;
   os_timer_disarm(&light_status_timer);
   os_timer_setfn(&light_status_timer, (os_timer_func_t *)led_status_timer_func , NULL);
   os_timer_arm(&light_status_timer,MAIN_TIMER_PERIOD,1);
   os_timer_disarm(&sleep_timer);
   os_timer_setfn(&sleep_timer, (os_timer_func_t *)sleep_timer_func , NULL);
   os_timer_arm(&sleep_timer,SLEEP_TIMER_PERIOD,1);
void sleep_init(void){
   wifi_fpm_set_sleep_type(LIGHT_SLEEP_T);     //set force sleep type, clsoe rf&cpu
   wifi_fpm_set_wakeup_cb(fpm_wakup_cb_func1); //Set fpm wakeup callback function
void sleep_start(void )
   os_printf("enter sleep mode\n\n");
   if(wifi_station_get_connect_status() == STATION_GOT_IP){
      while(!wifi_station_disconnect()){
         os_delay_us(10);
      os_printf("wifi disconnected\n\n");
   } else {
      smartconfig_stop();
      os_printf("wifi not connected\n\n");
   os_delay_ms(200);
   RED_LIGHT_OFF;
   wifi_set_opmode(NULL_MODE);               //set wifi mode to null mode.
   wifi_fpm_open();                        //enable force sleep fucntion
   int rst =  wifi_fpm_do_sleep(FPM_SLEEP_MAX_TIME);      // do sleep
   os_printf("sleep rst : %d",rst);
sleep_timer_func(void )
   static uint8_t cnt = 0;
   if(sleep_time_cnt < SLEEP_TIME_CNT){
      sleep_time_cnt++;
      os_printf("sleep_time_cnt: %d\n\n",sleep_time_cnt);
   }else {//2 min
      sleep_time_cnt = 0;
      os_timer_disarm(&KeyScan_timer);
      sleep_start();
JacksonLv
Re: Enter Light Sleep Mode cause reset
Postby JacksonLv » Fri Nov 02, 2018 4:04 pm
I add code in the user init to check the reset reason,it seems the wdt cause the reset,how can I fix this?all the timers are already turn off.
   struct rst_info *rst_info = system_get_rst_info();
   os_printf("reset reason: %x\n", rst_info->reason);
   if(rst_info->reason == REASON_WDT_RST || rst_info->reason == REASON_EXCEPTION_RST || rst_info->reason == REASON_SOFT_WDT_RST)
         if (rst_info->reason == REASON_EXCEPTION_RST)
            os_printf("Fatal exception (%d):\n", rst_info->exccause);
         os_printf("epc1=0x%08x, epc2=0x%08x, epc3=0x%08x, excvaddr=0x%08x, depc=0x%08x\n",rst_info->epc1, rst_info->epc2, rst_info->epc3, rst_info->excvaddr, rst_info->depc);
reset reason: 3
epc1=0x40232284, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
40232284:   ffff06           j   40232284 <fpm_do_sleep+0x20>
