【Feedback】SSL Memory leak on NONOS 1.5.3 / 1.5.4
sergione76
Postby sergione76 » Thu Jul 14, 2016 8:32 pm
test_lib.tar
(10 KiB) Downloaded 448 times
I've verified with the attached code that when a SSL handshake error occurs, a memory leak is generated
Moreover espconn_reconnect_callback is not called signaling ESPCONN_HANDSHAKE - TCP SSL handshake fails.
The code try to connect to a server every 10 seconds and every time SSL fails heap decrease of about 1952 bytes
The heap size in the output is printed by a timer in the user_main.
Have you ave any ideas?
Regards
Sergio
***Free heap=32072 ***
pm open,type:2 0
***timerConnect***
TCP: Connect to ip  XXX.XXX.XXX.XXX:4343
certificate.cer 30d
private_key.key 260
client handshake start.
client handshake failed
Error: SSL error 44
Disconnected
***Free heap=30088 ***
***timerConnect***
certificate.cer 30d
private_key.key 260
***Free heap=20160 ***
***Free heap=20224 ***
Error: SSL error 44
Disconnected
***Free heap=28136 ***
***timerConnect***
certificate.cer 30d
private_key.key 260
Error: SSL error 44
Disconnected
***Free heap=26184 ***
***timerConnect***
certificate.cer 30d
private_key.key 260
Error: SSL error 44
Disconnected
***Free heap=24232 ***
***timerConnect***
certificate.cer 30d
private_key.key 260
Error: SSL error 44
Disconnected
***timerConnect***
certificate.cer 30d
private_key.key 260
Error: SSL error 44
Disconnected
***Free heap=22280 ***
ESP_Rubin
Re: SSL Memory leak on NONOS 1.5.3 / 1.5.4
Postby ESP_Rubin » Fri Jul 15, 2016 12:12 pm
Have you tried our sample code?
Indefault, our sample code will tracking the free head of the system
ESP_Rubin
Re: 【Feedback】SSL Memory leak on NONOS 1.5.3 / 1.5.4
Postby ESP_Rubin » Fri Jul 15, 2016 1:30 pm
you can refer to:http://bbs.espressif.com/viewtopic.php?f=31&t=1564
sergione76
Postby sergione76 » Fri Jul 15, 2016 9:06 pm
I don't use RTOS SDK but NONOS SDK
ESP_Rubin
Postby ESP_Rubin » Mon Jul 25, 2016 10:11 am
NONOS reference code as link:http://bbs.espressif.com/viewtopic.php?f=31&t=389
