spi_flash_write at address 0 (zero)
DarkSide
Postby DarkSide » Wed Jul 27, 2016 5:16 am
Is it possible to write flash at address 0?
I want to update boot from my code, I using next code:
static const uint8_t BOOT_DATA[] ICACHE_RODATA_ATTR STORE_ATTR = { ... };
spi_flash_erase_sector(0);
spi_flash_write(0, (uint32*)&BOOT_DATA, sizeof(BOOT_DATA));
but looks like spi_flash_write does not writing. Instead of correct data I have all zeroes (dumping flash content to file to check).
Any suggestions?
tobewinner
Re: spi_flash_write at address 0 (zero)
Postby tobewinner » Wed Jul 27, 2016 12:20 pm
DarkSide wrote:Hello,
Any suggestions?
Try
spi_flash_write(0, (uint32*)BOOT_DATA, sizeof(BOOT_DATA));
DarkSide
Postby DarkSide » Wed Jul 27, 2016 4:28 pm
Ok, figured out. To make it work, first it's needed to copy content of array in flash into variable in memory: This code write data as expected:
uint32 *data = os_malloc(sizeof(BOOT_DATA));
os_memcpy(data, &BOOT_DATA, sizeof(BOOT_DATA));
/* copy current boot header code */
spi_flash_write(0, data, sizeof(BOOT_DATA));
os_free(data);
Now boot is updating and work as expected.
