hi,
i download SDK viewtopic.php?f=46&t=2349 from this link and i compile code so i got error of
./SDK/esp_iot_rtos_sdk-master/lib\libmain.a(app_main.o): In function `flash_data_check':
(.irom0.text+0x550): undefined reference to `user_rf_cal_sector_set'
(.irom0.text+0x631): undefined reference to `user_rf_cal_sector_set'
can any explain me this error and how can i solve this error.
[SOLVED] got error of user_rf_cal_sector_set in latest RTOS 1.4.2 SDK
valmik thakar
Postby valmik thakar » Fri Jul 29, 2016 1:18 pm
Re: got error of user_rf_cal_sector_set in latest RTOS 1.4.2 SDK
Postby pratik » Tue Aug 02, 2016 12:38 am
Please add this to your user_main.c:
Make sure that the corresponding sector contains blank.bin
uint32 ICACHE_FLASH_ATTR
user_rf_cal_sector_set(void)
uint32 rf_cal_sec = 0;
switch (size_map) {
rf_cal_sec = 128 - 8;
break;
rf_cal_sec = 256 - 5;
break;
rf_cal_sec = 512 - 5;
break;
rf_cal_sec = 1024 - 5;
break;
default:
rf_cal_sec = 0;
break;
return rf_cal_sec;
Re: [SOLVED] got error of user_rf_cal_sector_set in latest RTOS 1.4.2 SDK
Postby Rutharesh » Fri Aug 12, 2016 5:36 pm
I'ts worked for me.
But in the first line code i have removed "enum"
Thanks for the answer...
from "enum flash_size_map size_map = system_get_flash_size_map()"
to "flash_size_map size_map = system_get_flash_size_map();"
