【请教】ESP8266 接收 UDP 广播丢包
wsptr
Postby wsptr » Sat Jul 30, 2016 3:39 pm
使用 esp8266 接收来自计算机的广播包,丢帧十分严重。原以为是自己写的程序有问题,但是用了下面的例子以后仍然出现这个现象。
viewtopic.php?f=31&t=440&p=1682
具体的现象是这样的:当8266刚连接路由器以后,能够接收 UDP 广播,且不丢包;但当出现 pm open,type:2 0 提示(这个提示是什么意思?)后,就开始严重丢包,偶尔能接收到数据包。如果此时改发单播包,也会持续丢包,但过一段时间以后不再丢单播包。若再改为发广播包,则有较大的概率不再丢包。
在如下版本的 SDK 上进行了测试,均出现上述问题:
esp_iot_sdk_v1.3.0_15_08_08
esp_iot_sdk_v1.4.1_15_10_27
esp_iot_sdk_v1.5.0_15_11_27
esp_iot_sdk_v1.5.4_16_05_20
esp_iot_sdk_v1.5.4_16_05_20 with patch
请问这个问题应该如何解决?
     * Copyright 2013-2014 Espressif Systems
#include "ets_sys.h"
#include "os_type.h"
#include "osapi.h"
#include "mem.h"
#include "user_interface.h"
#include "espconn.h"
LOCAL os_timer_t test_timer;
LOCAL struct espconn user_udp_espconn;
const char *ESP8266_MSG = "I'm ESP8266 ";
LOCAL struct espconn ptrespconn;
  * FunctionName : user_udp_recv_cb
  * Description  : Processing the received udp packet
  * Parameters   : arg -- Additional argument to pass to the callback function
  *                pusrdata -- The received data (or NULL when the connection has been closed!)
  *                length -- The length of received data
  * Returns      : none
 LOCAL void ICACHE_FLASH_ATTR
 user_udp_recv_cb(void *arg, char *pusrdata, unsigned short length)
     os_printf("%s", pusrdata);
      * FunctionName : user_udp_send
      * Description  : udp send data
      * Parameters  : none
      * Returns      : none
 user_udp_send(void)
     char DeviceBuffer[40] = {0};
     char hwaddr[6];
     struct ip_info ipconfig;
     const char udp_remote_ip[4] = { 255, 255, 255, 255};
     os_memcpy(user_udp_espconn.proto.udp->remote_ip, udp_remote_ip, 4); // ESP8266 udp remote IP need to be set everytime we call espconn_sent
     user_udp_espconn.proto.udp->remote_port = 1112;  // ESP8266 udp remote port need to be set everytime we call espconn_sent
     wifi_get_macaddr(STATION_IF, hwaddr);
     os_sprintf(DeviceBuffer, "%s" MACSTR "!" , ESP8266_MSG, MAC2STR(hwaddr));
     espconn_send(&user_udp_espconn, DeviceBuffer, os_strlen(DeviceBuffer));
      * FunctionName : user_udp_sent_cb
      * Description  : udp sent successfully
      * Returns      : none
  user_udp_sent_cb(void *arg)
     return;
      os_printf("user_udp_send successfully !!!\n");
      //disarm timer first
       os_timer_disarm(&test_timer);
      //re-arm timer to check ip
      os_timer_setfn(&test_timer, (os_timer_func_t *)user_udp_send, NULL); // only send next packet after prev packet sent successfully
      os_timer_arm(&test_timer, 1000, 0);
 * FunctionName : user_check_ip
 * Description  : check whether get ip addr or not
 * Parameters   : none
 * Returns      : none
user_check_ip(void)
   //get ip info of ESP8266 station
    if (wifi_station_get_connect_status() == STATION_GOT_IP && ipconfig.ip.addr != 0)
      os_printf("got ip !!! \r\n");
      wifi_set_broadcast_if(STATIONAP_MODE); // send UDP broadcast from both station and soft-AP interface
      user_udp_espconn.type = ESPCONN_UDP;
      user_udp_espconn.proto.udp = (esp_udp *)os_zalloc(sizeof(esp_udp));
      user_udp_espconn.proto.udp->local_port = 50000;//espconn_port();  // set a available  port
      const char udp_remote_ip[4] = {255, 255, 255, 255};
      user_udp_espconn.proto.udp->remote_port = 9000;  // ESP8266 udp remote port
      espconn_regist_recvcb(&user_udp_espconn, user_udp_recv_cb); // register a udp packet receiving callback
      espconn_regist_sentcb(&user_udp_espconn, user_udp_sent_cb); // register a udp packet sent callback
      espconn_create(&user_udp_espconn);   // create udp
      user_udp_send();   // send udp data
   else
        if ((wifi_station_get_connect_status() == STATION_WRONG_PASSWORD ||
                wifi_station_get_connect_status() == STATION_NO_AP_FOUND ||
                wifi_station_get_connect_status() == STATION_CONNECT_FAIL))
         os_printf("connect fail !!! \r\n");
      else
            os_timer_setfn(&test_timer, (os_timer_func_t *)user_check_ip, NULL);
            os_timer_arm(&test_timer, 100, 0);
 * FunctionName : user_set_station_config
 * Description  : set the router info which ESP8266 station will connect to
 * Parameters   : none
 * Returns      : none
user_set_station_config(void)
   // Wifi configuration
   char ssid[32];
   char password[64];
   os_memset(ssid,0,32);
   os_memset(password,0,64);
   os_sprintf(ssid,"WSN");
   os_sprintf(password,"qazwsxedc");
   //need not mac address
   stationConf.bssid_set = 0;
   //Set ap settings
   //wifi_station_connect();
   wifi_station_dhcpc_start();
   //set a timer to check whether got ip from router succeed or not.
// For v1.5.4_16_05_20 with patch
uint32 user_rf_cal_sector_set(void)
   uint32 rf_cal_sec = 0;
   switch (size_map)
         rf_cal_sec = 128 - 5;
         break;
         rf_cal_sec = 256 - 5;
         break;
         rf_cal_sec = 512 - 5;
         break;
         break;
      default:
         rf_cal_sec = 0;
      break;
   return rf_cal_sec;
 * FunctionName : user_init
 * Parameters   : none
 * Returns      : none
void user_init(void)
   //Set softAP + station mode
   wifi_station_disconnect();
   wifi_station_dhcpc_stop();
   //ESP8266 connect to router
   user_set_station_config();
ESP_Rubin
Re: 【请教】ESP8266 接收 UDP 广播丢包
Postby ESP_Rubin » Mon Aug 01, 2016 2:14 pm
这个log应该是系统自动进入睡眠状态了,此时WIFI不是一直处于工作状态
wsptr
Postby wsptr » Mon Aug 01, 2016 6:58 pm
ESP_Rubin wrote:这个log应该是系统自动进入睡眠状态了,此时WIFI不是一直处于工作状态
可是此时系统才刚启动不到5秒啊……
使用wifi_set_sleep_type()可以避免这种情况出现吗?
ESP_Rubin
Postby ESP_Rubin » Tue Aug 02, 2016 11:43 am
你可以试一下
wsptr
Postby wsptr » Thu Aug 04, 2016 11:21 pm
ESP_Rubin wrote:你可以试一下
试过了,貌似确实有效。谢谢!!!
Users browsing this forum: No registered users and 313 guests
