For ESP8266_NONOS_SDK_V2.0.0 using libssl, the following conditions are needed:
if we are using certificate auth, we need to use the configTime API to provide SNTP, otherwise the certification will expire. We also do not support expire date > 2038.
What if udp :123 is closed by proxy? Is there way to set current time for "certificate auth" manually (from external rtc, ssldate, ntp over tcp/http)?
ypypy______
Re: ESP8266_NONOS_SDK_V2.0.0 using libssl
Postby kicer » Sun Aug 07, 2016 6:56 pm
When try to build v2.0.0 non-os sdk with NodeMcu, then got following errors~
looks like miss some sntp_set_xxx()/sntp_get_xxx() functions in libmain.a.
May I should implement this functions or need a SDK patch to fix it?
tks!
tks!
.a -Wl,--end-group -lm -o .output/eagle/debug/image/eagle.app.v6.out
/opt/nodemcu-firmware/sdk/esp_iot_sdk_v2.0.0/lib/libmain.a(time.o): In function `millis':
(.irom0.text+0xb8): undefined reference to `sntp_set_update_delay'
(.irom0.text+0xc1): undefined reference to `sntp_set_update_delay'
/opt/nodemcu-firmware/sdk/esp_iot_sdk_v2.0.0/lib/libmain.a(time.o): In function `updateTime':
(.irom0.text+0xe8): undefined reference to `sntp_set_daylight'
(.irom0.text+0xec): undefined reference to `sntp_set_timetype'
(.irom0.text+0xf0): undefined reference to `sntp_set_receive_time_size'
/opt/nodemcu-firmware/sdk/esp_iot_sdk_v2.0.0/lib/libmain.a(time.o): In function `configTime':
(.irom0.text+0x13c): undefined reference to `sntp_set_daylight'
(.irom0.text+0x144): undefined reference to `sntp_set_timetype'
(.irom0.text+0x171): undefined reference to `sntp_set_receive_time_size'
(.irom0.text+0x1b0): undefined reference to `sntp_get_timetype'
(.irom0.text+0x1c3): undefined reference to `sntp_get_timetype'
Users browsing this forum: No registered users and 319 guests
