I have problem with WPS. If I set the same SSID on two AP (routers), then the WPS do not work.
My SDK is:
1.5.4.1(39cb9a32)
Log:
mode : null
mode : sta(18:fe:34:d1:8a:9c)
add if0
wifi_wps_enable
wps scan
build public key start
build public key finish
f r0, scandone
f r0, scandone
f r0, wps discover [myssid]
scandone
WPS: neg start
f r0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 0 (d)
At this moment the function passed to wifi_set_event_handler_cb is called:
disconnect from ssid myssid, reason 203
After about 2 minutes the function passed to wifi_set_wps_cb is called with argument WPS_CB_ST_TIMEOUT.
If the two AP have different SSID after step state: 2 -> 3 (0) is:
state: 3 -> 5 (10)
add 0
aid 1
cnt
process pubkey start
process pubkey finish
WPS: key[mykey]
wps finished
