配置文件:
#define CHIP_TYPE_1 ESP8266 #ESP8089 or ESP8266
#define LOG_PATH_1 ./logs #log saving path, user could modify their own folder
#define FACTORY_INFO_1 ESP #fill factory id or factory name
#define COMPORT_1 9
#define BAUDRATE_1 115200 #26m晶振需要减小波特率(230600)
#define IMGPATH_1 ./image/eagle.app.flash_MODULE_TEST_26m_tout_151229.bin
#define FREQ_1 26 #晶振频率
#define AUTOSTART_1 0 #1:自动开始下一次测试 0:手动开始
#define INSTRUMENT_EN_1 0 #使能仪器测试模式
#define IPADDR_IQV_1 192.168.100.254 #iqview 仪器IP地址
#define IPADDR_PC_1 192.168.100.186 #PC IP地址
#define TESTER_1 LITEPOINT #不要更改
#define RFPORT_1 1 #1:left 2:right
#define INPUT_ATTEN_EN_1 1 #use input path loss to test tx
#define PATH_ATTEN_1 21 #practical attenuation in the path
#define PATH_ATTEN_DIFF_ALARM_1 5 #固定 设置线路衰减与计算值的最大偏差 超过会报错提示
#define PATH_ATTEN_TX_CRT_1 0 #CORRECT VAL FOR TX GAIN
#define PATH_ATTEN_CAL_CHANNEL_1 1,6,11,14 #CALCULATE PATH ATTEN IN THIS CHANNEL
#define PRINT_MAC_EN_1 1 #set 1 to print MAC after
#define PRINT_MAC_AUTO_1 0 #set 1 to print MAC automatically
#define PRINT_MAC_COMMAND_1 ./mac_printer/8266_MAC2DPrint.exe
#define UPLOAD_CMD_PATH_1 ./result_upload/ADS_8266.exe
#define UPLOAD_SN_RES_EN_1 1 #enable upload test result and SN
#define UPLOAD_SN_LENGTH_1 12 #length of SN string
#define UPLOAD_SN_AUTO_START_1 1 #输入满UPLOAD_SN_LENGTH长度的SN号后,自动开始测试,重启或者点击开始后下次生效
#define ANALOGTEST_1 1
#define TXTEST_1 1
#define RXTEST_1 1
#define SKIP_DOWNLOAD_1 0
#define SET_MAC_EN_1 0 #support burn customer Mac
#define MAC_INPUT_EN_1 0
#define MAC_CRC_EN_1 0
#define MAC_OFFSET_1 0x7c000 # mac burn addr
#define MAC_START_1 A00000000000 #mac start addr
#define MAC_END_1 A00000000008 #mac end addr
#define MAC_CURRENT_1 A00000000000
#define DEBUG_EN_1 1
#define ANTENNA_1 1 #1:天线测试 0:cable测试
#define INITFROMXLS_1 0 #这项不要更改
#define START_DELAY_1 200 #四个模块时间相互错开,单位ms
#define GPIO_TEST_EN_1 0
#define GPIO_TEST_PIN_1 0x3030
#define GPIO_TEST_VAL_1 0x1010
#define GPIO_TEST_READ_EN_1 0
#define GPIO_TEST_VAL_TARGET_1 0x3030
#define ADC_TEST_EN_1 0
#define EFUSE_MODE_1 1 # 0: NOT USED ; 1:NORMAL
#define USER_FW_DOWNLOAD_EN_1 0 #0: disable ; 1: enable
#define USER_FW_DOWNLOAD_PORT_1 SPI #SPI OR HSPI
#define USER_FW_FORCE_DOWNLOAD_1 0 #0:download if RF test pass ; 1:download after test
#define USER_FW_VER_TEST_EN_1 0 #0: disable ; 1: uart 2: gpio
#define USER_FW_VER_STR_1 v1.0.02
#define USER_FW_FILE_NUM_1 1
#define USER_FW_PATH0_1 ./bin/test.bin
#define USER_FW_ADDR0_1 0x0
#define USER_FW_PATH1_1 ./bin/test.bin
#define USER_FW_ADDR1_1 0x0
#user fw version, when system restart print : esp_user_fw_version:xxxx
#define USER_TEST_CMD_EN_1 0 #Send user test command
#define USER_TEST_CMD_NUM_1 2 #TEST COMMAND NUMBER
#define USER_TEST_CMD0_1 AT+CWLAP\r\n
#define USER_TEST_RESP0_1 OK
#define USER_TEST_TIMEOUT0_1 5 #S
#define USER_TEST_CMD1_1 AT+CWLAP\r\n
#define USER_TEST_RESP1_1 OK
#define USER_TEST_TIMEOUT1_1 5 #S
#define USER_TEST_CMD2_1 AT+CWJAP\r\n
#define USER_TEST_RESP2_1 OK
#define USER_TEST_TIMEOUT2_1 5 #Slog信息:
TOOL_VERSION: 4.9.5
FACTORY: esp
MODULE_TEST START!!!
phy_version: 20130913_b1 Dec 29 2015 11:51:10
CHIP_VERSION: 0x0
CHIP_ID: 0x5ccf7f64
rc_cal_dout=29, rx_filt_dcap=14, tx_filt_dcap=23
vdd33=3379, temp_code=0, offset=0
cal_rf_ana_gain, rf_gain=0x1f, ana_gain=0x10, bb_atten=6
rxiq_tot_pwr1=33dB, k=0
RX_NOISEFLOOR, -388
RX_NOISEFLOOR, -386
RX_NOISEFLOOR, -392
RX_NOISEFLOOR, -392
TXCAP_TMX2G_CCT_LOAD, 13, 15, 15,
TXCAP_PA2G_CCT_STG1, 3, 3, 1,
TXCAP_PA2G_CCT_STG2, 2, 1, 1,
TX_POWER_BACKOFF, 9, 10, 11, 10,
TX_PWRCTRL_ATTEN, -24, -4, 7, 13, 17, 26, -23, -3, 8, 15, 19, 27, -22, 4, 9, 15, 20, 28, -23, -4, 7, 14, 18, 27,
TXIQ, 4, 12
TXDC, 79, 77; 78, 69; 78, 67; 78, 66;
RXIQ, 0, -1; 0, -2; 1, -2; 1, -2; 1, -2;
RXDC, 257, 251, 256, 256; 257, 252, 256, 256; 258, 252, 256, 256; 258, 252, 256, 256; 257, 252, 256, 256; 258, 252, 256, 256; 259, 253, 256, 256; 259, 253, 256, 256; 259, 254, 256, 253; 258, 254, 258, 253; 259, 253, 256, 256; 259, 254, 256, 256; 260, 254, 256, 256; 260, 254, 256, 256; 260, 254, 256, 256; 260, 254, 253, 256; 259, 254, 256, 256; 259, 254, 256, 256; 259, 254, 256, 255; 259, 254, 256, 256; 260, 254, 251, 257; 259, 254, 256, 256; 259, 254, 256, 256; 259, 254, 256, 256; 259, 254, 256, 255; 259, 254, 256, 256; 260, 254, 251, 257; 259, 254, 256, 256; 259, 254, 256, 256; 259, 254, 256, 256;
SVN_LOG=772
TX_VDD33=3379
TOUT=13
TEST_NUM=1, TEST_TIME=436172us
MODULE_ANA TEST END!!!
tx packet test ..
txp_pwctrl_atten: 3
rombist_rslt: 0
fb_rxrssi: 55, 55, 54, 53, 52, 53,
dut_rxrssi: 61, 61, 61, 61, 61, 61,
fb_rx_num: 14, 14, 16, 15, 16, 16,
dut_rx_num: 14, 14, 16, 15, 16, 16,
FREQ_OFFSET, -13, -12, -13, -13,
txp_state: 0xffffffffdffffffff77fb7ff, 0xffffffffdffffffff77fb7ff;
txp_result: 91, 91, 0
0: req_suc:1 req_times:1 data_suc:1 txdata_use_timer:0x636f 96 txreq_start_time:0x72694b txdata_start_time:0x761307
init_time=402935us
MODULE_TEST END!!!
EFUSE LOG:
REG0:6A5A0000
REG1:02008218
REG2:6400b000
REG3:005CCF7F
EFUSE NORMAL MODE
EFUSE CHECK PASS...-------------------------
TOOL_VERSION: 4.9.5
FACTORY: esp
logs here:
Part failure in TX_POWER_BACKOFF #0,#0 : 0.000000 !< 9.000000 !< 8.000000
Part failure in TX_POWER_BACKOFF #0,#1 : 0.000000 !< 10.000000 !< 8.000000
Part failure in TX_POWER_BACKOFF #0,#2 : 0.000000 !< 11.000000 !< 8.000000
Part failure in TX_POWER_BACKOFF #0,#3 : 0.000000 !< 10.000000 !< 8.000000
