Is tls still not supported on the ESP8266_IOT_PLATFORM?
gustavo
Postby gustavo » Wed Aug 10, 2016 11:00 pm
If you inspect the code in the ESP8266_IOT_PLATFORM (https://github.com/espressif/ESP8266_IO ... ree/master) project you will reach the following:
/*SSL not Ready*/
//#define SERVER_SSL_ENABLE
//#define CLIENT_SSL_ENABLE
This being said, the programming guide for ESP RTOS already contains a section on SSL client connections.
What is the actual state of SSL support on ESP8266 RTOS SDK?
I'm mostly interested in tls server configuration.
Users browsing this forum: No registered users and 310 guests
