Compiling rtos sdk idf project with CMake
Postby Deous » Fri Feb 15, 2019 12:56 am
I am not sure if anyone tried that but I was able to compile and flash nodeMCU under Windows 10 using VSC IDE and CMake tools supplied with rtos sdk for esp-idf. Anyways looked good except code does nothing. Blue led is on and that's it.
Any thoughts or advices how to fix it ?
flynnpayne
Re: Compiling rtos sdk idf project with CMake
Postby flynnpayne » Wed Dec 18, 2019 5:00 pm
How did you fix it?
Postby Deous » Tue Mar 03, 2020 11:33 pm
OK just to let anybody know - ESP8266_FREERTOS_SDK IDF style can compile esp32 code
I tested it and works fine. No flash tool needed or Arduino hassle.
I tested esp-01 and esp8285 all works very nice and compiles with CMake
Just download sdk and new toolchain
Cheers
Cheers
Postby Deous » Fri Mar 13, 2020 11:31 pm
It is incomplete answer but - YES. You compile code with same idf.py command but you need to switch IDF_PATH to your SDK
The code is not entirely identical but uses same esp-idf style and it is ridiculously easy to modify for esp8266.
Postby mriksman » Fri Mar 13, 2020 11:41 pm
Thanks. I finally downloaded both SDKs and Toolchains and configured VSCode. SO much better than PlatformIO (which uses ESP8266 RTOS 1.5). It's great being able to have code that can be (almost) reused on both chips.
The sooner Espressif roll BOTH ESP8266 and ESP32 into a single IDF, the better!
Postby mriksman » Mon Mar 16, 2020 5:38 am
Windows 10 and Python 3.8 and idf.py works fine. I saw a reference to issues with ESP-IDF and Python 3.x on Espressif’s documents, but so far I haven’t had any issues.
What issues are you facing?
