[survey] which software you use for making apk
User avatar
rudi
Postby rudi » Sat Mar 14, 2015 1:13 am
hi
would ask here, which software the most people here take for making apk.
i am personaly a fan of Basic4Android, the new version has inline coding in pure java. [1]
can you post your favority android stuff too?
think the most people works in eclipse and java, right?
would be nice for share infos, perhaps then more will write here in this theme?
best wishes
rudi :)
[1] http://www.b4x.com/
問候飛出去的朋友遍全球魯迪
muris
Contact:
Re: [survey] which software you use for making apk
Postby muris » Sat Mar 14, 2015 2:39 am
Hi rudi,
I developed my app in Eclipse (native Android app). It is open source and the source code can be found here: https://github.com/elektronika-ba/ctrl-android-test1 (APK is here: http://www.ctrl.ba/CtrlTest1.apk)
It is a universal app template that can be extended for your purposes. I paused development and will continue to work on it again in next few days, so new features are to be expected :D Also documentation needs to be written :o
ESP8266 requires firmware that can be found here: https://github.com/elektronika-ba/ctrl-esp8266-v0.9.2
There is also firmware for SDK 0.9.4 but I will soon update to the latest SDK version.
Option 1:
It uses a cloud (server) to connect to ESP8266 devices. I published a cloud server to www.ctrl.ba if you want to test it out! SSL certificates are self-signed so you will see warnings in your browser when you first access the admin panel.
Option 2:
You can deploy a cloud server on PC in your local network if you don't want to use Internet to control your ESP8266.
a) Cloud server source code is here: https://github.com/elektronika-ba/ctrl-server
b) Cloud server web administration is in PHP and can be found here: https://github.com/elektronika-ba/ctrl-webadmin
Regards,
Muris
User avatar
rudi
Postby rudi » Sat Mar 14, 2015 3:08 am
Hi Muris, super! Mnogi Hvala!
Ja ću pokušati ponovo.
libs & Funkcije stvaram sa Eclipse
Kako si? Nadam se da si dobro!
Najbolje želje da vas iz Njemačke :)
Hi Muris, super, many thank to you.
i will try it.
libs and function i create in eclipse too.
how are you, hope you are fine! :)
best wishes to you from germany :)
Hallo Muris, fantastisch! Vielen Dank!
Das werde ich einmal probieren.
libs & Funktionen erstelle ich auch mit eclipse
Wie geht es Dir? Ich hoffe es geht dir gut!
Beste Grüsse zu Dir von germany :)
:) lol
rudi ;-)
問候飛出去的朋友遍全球魯迪
muris
Contact:
Postby muris » Sat Mar 14, 2015 5:52 am
:lol:
You are welcome rudi. I hope you will like my project :)
My goal is that we all together make something cool and useful.
Best regards from Bosnia!
Nema na cemu rudi. Nadam se da ce ti se svidjeti moj projekat.
Ideja mi je da svi zajedno napravimo nesto super i korisno.
Sve najbolje iz Bosne!
Best regards,
Muris
