Inverse UART output? (for WS2812 )
Postby Lars R. » Tue Nov 04, 2014 9:27 pm
********** EDIT: NOTE for those who try this: After the start-bit, the UART sends LSB first. **********
is it possible to inverse the output of the UART. Output 1 instead of 0 and 0 instead of 1.
Background of Question: Using the UART for controlling WS2812 after the following scheme:
(1)xx xxx xx(0).
UART with 7 data bits.
3 Bits of WS2812.
According to viewtopic.php?f=7&t=24 , UART seems to be fast enough.
thx and regards
Lars
(1)xx xxx xx(0).
3 Bits of WS2812.
thx and regards
Lars
Re: Inverse UART output? (for WS2812 )
Postby costaud » Wed Nov 05, 2014 1:44 am
At least you can build an inverse circuit by a transistor.
We will check the control register later.
This feature should add to the next generation !!
post it in the url below.
http://bbs.espressif.com/viewtopic.php?f=7&t=12
Postby costaud » Thu Nov 06, 2014 2:10 am
SET BIT22 OF UART_CONF0 REG, SO THAT THE TXD OUTPUT INVERSE
SET_PERI_REG_MASK(UART_CONF0(UART0) , BIT22);
0x20 UART_CONF0
uart_dtr_inv [24]
uart_rts_inv [23]
uart_txd_inv [22]
uart_dsr_inv [21]
uart_cts_inv [20]
uart_rxd_inv [19]
0x20 UART_CONF0
uart_dtr_inv [24]
uart_rts_inv [23]
uart_txd_inv [22]
uart_dsr_inv [21]
uart_cts_inv [20]
uart_rxd_inv [19]
nicoverduin
Postby nicoverduin » Thu Nov 06, 2014 5:25 pm
As I am playing around a lot with the WS2812b.... Could UART actually be used as the pulse widths determine the "0" and "1"?
Postby Lars R. » Thu Nov 06, 2014 6:22 pm
nicoverduin wrote:As I am playoing around alot with the WS2812b.... Could UART actually be used as the pulse widths determine the "0" and "1"?
I don't now. But the idea in more detail is the following:
WB: Number of WS2812 Bits per UART Char
USYMB: UART Symbols per UART Char inclunging start-bit and stop-bit
WS: time of WS2812 short pulse
WL: time of WS2812 long pulse
UBAUD: Baudrate of UART
Sending USYMB Symbols within the time of WB*(WS+WL)
-> UBaud= 1/ ( WB*(WS+WL)/Usymb)
Example 1
WB=3 (3*8=24) -> 8 UART char per WS2812-LED
USYMB=9 -> 7 data bits
WS=0.4us
WL=0.8us
=> UBAUD= 2.5Mbps
Send the 3 WS2812 bits "011":
1. Ratio (1:2): 100 110 110
2. Inverse: 011 001 001 (costaud wrote about HOWTO inverse the UART output)
3. Consider start and stop bit (0)11 001 00(1) (it's inversed now)
4. Reverse data : (0) 00 100 11 (1) (After start-bit, UART sends LSB of data first)
5. Data word to UART: x00 100 11 (UART is set to 7 Bit, but interface is byte)
Example 2
WS=0.5us
WL=1.0us
=> UBAUD= 2.0Mbps
Examble 3
WB=2 (2*12)=24 -> 12 UART char per WS2812-LED
USYMB=8 -> 6 data bits
WS=0.3125us
WL=0.9375us
Ratio (1:3)
=> UBAUD= 3.2Mbps
Edit: Replaced "wrong name" by costaud. sorry.
nicoverduin
Postby nicoverduin » Thu Nov 06, 2014 9:14 pm
I think I understand what you mean
But why not redesign the library FastLED from Paul Stoffregen. I have worked with it before and am quite happy with it.
