What does it mean "link is builded"?
Postby akouz » Tue Aug 30, 2016 7:48 am
AT version:1.3.0.0(Jul 14 2016 18:54:01)
SDK version:2.0.0(656edbf)
compile time:Jul 19 2016 18:43:55
Occasionally I get the following response to AT+CIPMUX=1 command:
AT+CIPMUX=1
link is builded
ERROR
This response is not described in documentation. What does it mean?
AT+CIPMUX=1
link is builded
ERROR
Re: What does it mean "link is builded"?
Postby pratik » Fri Sep 02, 2016 10:23 am
I will consult a firmware engineer and get back to you soon.
Postby ESP_Rubin » Mon Sep 05, 2016 3:10 pm
Hi Sir:
for AT+CIPMUX, something need your notification:
1. "AT+CIPMUX=1" can only be set when transparent transmission disabled( "AT+CIPMODE=0")
2. This mode can only be changed after all connections are disconnected.
3. If TCP server is started, has to delete TCP server first, then change to single connection is allowed.
if you done fellow the steps and still meet the problem, please list the reproduce steps for my verification
Postby akouz » Tue Sep 06, 2016 7:12 am
ESP_Rubin wrote:1. "AT+CIPMUX=1" can only be set when transparent transmission disabled( "AT+CIPMODE=0")
Thank you. I am aware of that because it is described in the AT+CIPMUX command description.
Postby ESP_Rubin » Tue Sep 06, 2016 9:53 am
hi sir,
My steps for your reference, "AT+CIPMUX" works ok
- Attachments
- CIPMUX.zip
- (28.87 KiB) Downloaded 673 times
Postby akouz » Tue Sep 06, 2016 11:57 am
ESP_Rubin wrote:hi sir,
I use the same steps, initially it was OK too. Then I added more AT+CIPMUX=1 commands. Most of them are OK, but sometimes I see "link is builded ERROR" reply.
