FOTA user1 can't be started - bootloader 1.6 issue
FrenkR
Postby FrenkR » Wed Sep 14, 2016 5:57 pm
using SDK 2.0 and bootloader 1.6. Configuration is 32m-c1, mode=6 (1024kb + 1024kb). start address for user1 = 0x1000, for user2 = 0x101000.
I've did a dump of complete bin on address 0x1000 and 0x101000. Both are binary the same. So bin is correctly uploaded to flash(both user1 and user2).
When starting using "user1", following output is received from bootloader:
tail 8
chksum 0xe5
tail 8
chksum 0x84
tail 8
chksum 0xd8
csum 0xd8
2nd boot version : 1.6
  SPI Speed      : 40MHz
  SPI Mode       : QIO
  SPI Flash Size & Map: 32Mbit(1024KB+1024KB)
jump to run user1 @ 1000
error magic!
first boot failed, reboot to try backup bin
when starting "user2", everything is correct:
tail 8
chksum 0xe5
tail 8
chksum 0x84
tail 8
chksum 0xd8
csum 0xd8
  SPI Speed      : 40MHz
  SPI Mode       : QIO
jump to run user2 @ 101000
It looks like bootloader is broken when starting user1.bin. Can you check bootloader code, please?
Rgds,
Frenk
Users browsing this forum: No registered users and 296 guests
