How to setup ESP Mesh network
Postby rajendra » Sat Sep 17, 2016 5:28 pm
I have compiled MESH DEMO & downloaded it to ESP.
How to specify which ESP will play role of root node & which will be non root?
ESP_Alen
Re: ESP Mesh network
Postby ESP_Alen » Mon Sep 19, 2016 2:34 pm
rajendra wrote:Is there any guide to create ESP mesh network?
Please follow up the README of git repository.
devices will contest for root device, and the other device will work as non-root device.
Postby rajendra » Mon Sep 19, 2016 2:37 pm
This is how my user_config.h looks
#ifndef __USER_CONFIG_H__
#define __USER_CONFIG_H__
#include "c_types.h"
#define MESH_DEMO_PRINT ets_printf
#define MESH_DEMO_STRLEN ets_strlen
#define MESH_DEMO_MEMCPY ets_memcpy
#define MESH_DEMO_MEMSET ets_memset
#define MESH_DEMO_FREE os_free
static const uint16_t server_port = 7000; /*PORT USED BY USER IOT SERVER FOR MESH SERVICE*/
static const uint8_t server_ip[4] = {192, 168, 100, 153}; /*USER IOT SERVER IP ADDRESS*/
static const uint32_t UART_BAUT_RATIO = 115200; /*UART BAUT RATIO*/
static const uint8_t MESH_GROUP_ID[6] = {0x18,0xfe,0x34,0x00,0x00,0x50}; /*MESH_GROUP_ID & MESH_SSID_PREFIX REPRESENTS ONE MESH NETWORK*/
static const uint8_t MESH_ROUTER_BSSID[6] = {0xF0, 0xB4, 0x29, 0x2C, 0x7C, 0x72}; /*MAC OF ROUTER*/
* please change MESH_ROUTER_SSID and MESH_ROUTER_PASSWD according to your router
#define MESH_ROUTER_SSID "MeshAP" /*THE ROUTER SSID*/
#define MESH_ROUTER_PASSWD "1234509876ABCDEF" /*THE ROUTER PASSWORD*/
#define MESH_SSID_PREFIX "MESH_DEMO" /*SET THE DEFAULT MESH SSID PREFIX;THE FINAL SSID OF SOFTAP WOULD BE "MESH_SSID_PREFIX_X_YYYYYY"*/
#define MESH_AUTH AUTH_WPA2_PSK /*AUTH_MODE OF SOFTAP FOR EACH MESH NODE*/
#define MESH_PASSWD "123123123" /*SET PASSWORD OF SOFTAP FOR EACH MESH NODE*/
#define MESH_MAX_HOP (4) /*MAX_HOPS OF MESH NETWORK*/
#endif
Please suggest what am I doing wrong?
ESP_Alen
Postby ESP_Alen » Mon Sep 19, 2016 5:56 pm
rajendra wrote:What should be Mesh router's SSID? Is this suppose to be WIFI router's SSID or anything which will be used bye ESP devices to form mesh?
#endif
MESH_ROUTER_SSID: SSID of router AP
MESH_ROUTER_PASSWD: Password of router AP
server_ip: IP address of your server (demo_server.py)
MESH_SSID_PREFIX: SSID prefix of mesh AP (Device AP, not router AP)
MESH_PASSWD: Password of mesh AP (Device AP, not router AP).
Re: How to setup ESP Mesh network
Postby rajendra » Mon Sep 19, 2016 8:33 pm
demo_server is running on 192.168.100.153 port 7000 (this machine is also connected on "MeasAP" wifi network)
I use python esptool to download bin to esp device with following commands
python esptool.py -p /dev/ttyUSB0 write_flash --flash_freq=40m --flash_mode=qio --flash_size=8m 0x00000 /home/rajendra/espressif/ESP8266_MESH_DEMO-1.3.1/bin/eagle.flash.bin
python esptool.py -p /dev/ttyUSB0 write_flash --flash_freq=40m --flash_mode=qio --flash_size=8m 0x40000 /home/rajendra/espressif/ESP8266_MESH_DEMO-1.3.1/bin/eagle.irom0text.bin
When I turn on ESP devices there is no request to demo_server nor "MESH-DEMO......" acitve ssid.
When I connect to UART of ESP module I get following response.
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
scan-ch:0
scandone
scan-ch:0
I have attached binary files generated which I ma downloading to device.
What could be wrong?
- Attachments
- bin.zip
- (212.53 KiB) Downloaded 491 times
ESP_Alen
Postby ESP_Alen » Wed Sep 21, 2016 6:27 pm
rajendra wrote:My wifi network's SSID is "MeshAP" & password is "1234509876ABCDEF"
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
scan-ch:0
scandone
scan-ch:0
What's version of mesh you used ? master, debug or debug_for_light branch ?
Please follow the steps:
How to build run image:
1. Obtain IP address of local server.
2. Change server_ip in user_config.h according to the IP address of local server.
3. Run ./gen_misc.h
boot version: boot_v1.2+
bin generate: user1.bin
spi speed: 40MHz
spi mode: QIO
spi size and map: 1024 (512KB + 512KB)
Download image to device:
1. Get download tools from the official website of Esressif at http://espressif.com.
2. Download the following four files in ./bin/ to device:
file download_address
esp_init_data_default.bin 0xfc000
blank.bin 0xfe000
boot_v1.4(b1).bin 0x00000
upgrade/user1.1024.new1.bin 0x01000
NOTE: Before starting to download, please make sure you have selected the right flash size (8 Mbit).
Postby rajendra » Wed Sep 21, 2016 8:13 pm
https://github.com/espressif/ESP8266_MESH_DEMO
When I run gen_misc.sh & choose any other options other than default gives error as below.
enter(0/1/2, default 2):
1
gen_misc.sh: 14: [: 1: unexpected operator
gen_misc.sh: 16: [: 1: unexpected operator
boot mode: none
I tried to use make directly with following parameters, but it is not creating upgrade/user1.bin. (There is no upgrade folder under bin)
make COMPILE=gcc BOOT=new APP=1 SPI_SPEED=40 SPI_MODE=QIO SPI_SIZE_MAP=0
I this a correct branch?
ESP_Alen
Postby ESP_Alen » Thu Sep 22, 2016 11:08 am
rajendra wrote:I am using ESP Mesh Demo from master branch
1
boot mode: none
Please use dos2unix to format gen_mish.sh
ESP_Alen
Postby ESP_Alen » Fri Sep 23, 2016 6:25 pm
rajendra wrote:Thank you Alen, It is working now.
welcome.
Users browsing this forum: No registered users and 291 guests
