not startup after wdt reset serveral times.
Postby xyuz » Wed Mar 18, 2015 3:18 pm
not startup after wdt reset serveral time.
this is the log:
wdt reset
tail 0
chksum 0x8d
tail 12
chksum 0xcf
ho 0 tail 12 room 4
tail 4
chksum 0xcf
csum 0xcf
2nd boot version : 1.2
SPI Speed : 40MHz
SPI Mode : QIO
SPI Flash Size : 4Mbit
jump to run user1
Fatal exception (0):
epc1=0x40213902, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
this is the log:
wdt reset
tail 0
chksum 0x8d
tail 12
chksum 0xcf
ho 0 tail 12 room 4
tail 4
chksum 0xcf
csum 0xcf
SPI Speed : 40MHz
SPI Mode : QIO
jump to run user1
Re: not startup after wdt reset serveral times.
Postby ESP_Faye » Thu Mar 19, 2015 11:38 am
Please try it with boot_v1.3
And you could find the error address 0x40213902 in .S file, for example , you are running user1.bin now,check user1.S and find which funcion dose 0x40213902 located in.
Postby xyuz » Thu Apr 16, 2015 11:04 am
1.这个问题好像是在boot过程中还未运行至user.bin时程序崩溃,这时候是不是看门狗还没启动,用的是boot1.2,不知道1.3是否处理了这个问题?
2.另外,往SPI上读指令时好像会出现读取到错误指令,之前观察过一个exception看.S发现对应的指令是不可能出错的(加法指令),但是exception报的是非法内存访问的exception。
Postby xyuz » Wed Apr 22, 2015 11:24 am
今天又出现了次看门狗复位没起来,SDK版本 1.0.0,boot1.2,以下是日志:
wdt reset
tail 0
chksum 0x8d
tail 12
chksum 0xcf
ho 0 tail 12 room 4
tail 4
chksum 0xcf
csum 0xcf
SPI Speed : 40MHz
SPI Mode : QIO
jump to run user1
01-01 00:00:00 Hal.c::checkStartupState[24]:
//输出了一些乱码之后就没起来了
重新上电之后还是能正常工作的。
麻烦分析一下有可能是什么问题导致的复位没起来?
wdt reset
tail 0
chksum 0x8d
tail 12
chksum 0xcf
ho 0 tail 12 room 4
tail 4
chksum 0xcf
csum 0xcf
SPI Speed : 40MHz
SPI Mode : QIO
jump to run user1
//输出了一些乱码之后就没起来了
重新上电之后还是能正常工作的。
Users browsing this forum: No registered users and 40 guests
