Can't connect to ap from devices
traderlopez
Postby traderlopez » Thu Sep 29, 2016 12:55 pm
I then set up a Raspberry PI as router. I tested it connecting to internet from my laptop through it, and also my mobile gets wifi through it, and everything seems right there.
Then I changed user_config to reflect the change on the mesh devices, and they don't connect.
They don't even try to connect to it, as I can see the connection tries live on the screen attached to the PI and it doesn't show anything when I switch on the mesh devices.
This is the serial log of a device. It always ends up in a "enable mesh fail, re-enable" and goes on scanning (on channel 0?). I don't know, but I think it should scan all channels.
;lESP-TOUCH FLOW INIT...
ESP-TOUCH SET STATION MODE ...
SC version: V2.5.4
flush ssid: pwd:@úÿ?@úÿ?
mesh version: v1.3.2
mode : sta(5c:cf:7f:c1:07:d5)
add if0
scandone
err,scan status 1
scandone
err,scan status 4
ESP-TOUCH TIMEOUT
mode : sta(5c:cf:7f:c1:07:d5) + softAP(5e:cf:7f:c1:07:d5)
add if1
bcn 100
scandone
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
mesh_enable_cb
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
mesh_enable_cb
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
mesh_enable_cb
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
mesh_enable_cb
scan-ch:0
scandone
This is another device that has the PI router in range:
SC version: V2.5.4
add if0
scandone
err,scan status 1
scandone
err,scan status 4
ESP-TOUCH TIMEOUT
add if1
bcn 100
scandone
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
mesh_enable_cb
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
mesh_enable_cb
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
mesh_enable_cb
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
mesh_enable_cb
scan-ch:0
scandone
This is user_config.h. I changed the server_ip, the MESH_ROUTER_BSSID, ROUTER_SSID and ROUTER_PASS. Also there is no server at this time at that address, but the devices don't get a wifi connection, I don't think they will ask for the server yet.
static const uint16_t server_port = 7000; /*PORT USED BY USER IOT SERVER FOR MESH SERVICE*/
static const uint8_t server_ip[4] = {192, 168, 10, 1}; /*USER IOT SERVER IP ADDRESS*/
static const uint32_t UART_BAUT_RATIO = 115200; /*UART BAUT RATIO*/
static const uint8_t MESH_GROUP_ID[6] = {0x18,0xfe,0x34,0x00,0x00,0x50}; /*MESH_GROUP_ID & MESH_SSID_PREFIX REPRESENTS ONE MESH NETWORK*/
//static const uint8_t MESH_ROUTER_BSSID[6] = {0x00, 0x80, 0x5A, 0x5B, 0x1B, 0xAD};
/*MAC OF ROUTER*/
static const uint8_t MESH_ROUTER_BSSID[6] = {0x00, 0x0B, 0x81, 0x88, 0x63, 0x83};
* please change MESH_ROUTER_SSID and MESH_ROUTER_PASSWD according to your router
#define MESH_ROUTER_SSID "PitAP" /*THE ROUTER SSID*/
#define MESH_ROUTER_PASSWD "*8*8*8*8*8*8*8*" /*THE ROUTER PASSWORD*/
#define MESH_SSID_PREFIX "MEMO" /*SET THE DEFAULT MESH SSID PREFIX;THE FINAL SSID OF SOFTAP WOULD BE "MESH_SSID_PREFIX_X_YYYYYY"*/
#define MESH_AUTH AUTH_WPA2_PSK /*AUTH_MODE OF SOFTAP FOR EACH MESH NODE*/
#define MESH_PASSWD "3HappyLions" /*SET PASSWORD OF SOFTAP FOR EACH MESH NODE*/
#define MESH_MAX_HOP (4) /*MAX_HOPS OF MESH NETWORK*/
ESP_Alen
Re: Can't connect to ap from devices
Postby ESP_Alen » Thu Sep 29, 2016 1:02 pm
traderlopez wrote:Yesterday my WAN router died.
SC version: V2.5.4
add if0
scandone
err,scan status 1
scandone
err,scan status 4
ESP-TOUCH TIMEOUT
add if1
bcn 100
scandone
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
mesh_enable_cb
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
mesh_enable_cb
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
mesh_enable_cb
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
mesh_enable_cb
scan-ch:0
scandone
SC version: V2.5.4
add if0
scandone
err,scan status 1
scandone
err,scan status 4
ESP-TOUCH TIMEOUT
add if1
bcn 100
scandone
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
mesh_enable_cb
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
mesh_enable_cb
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
mesh_enable_cb
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
mesh_enable_cb
scan-ch:0
scandone
/*MAC OF ROUTER*/
The router ssid is different from "PitAP", please pay attention to statement with red color.
Please use scenario of mesh_performance, and modify user_config.h in mesh_performance/include
traderlopez
Postby traderlopez » Thu Sep 29, 2016 2:47 pm
I run gen_misc.sh from the mesh_demo folder. I check the timestamp of the output files being saved in the flash and the update file has the correct updated date. I don't understand how the performance scenario folder user_config.h can have some influence on the demo files I changed in the demo folder.
If it is possible, please explain me as shortly as you wish how to switch scenarios between demo and performance.
Thanks very much.
traderlopez
Postby traderlopez » Thu Sep 29, 2016 3:17 pm
SC version: V2.5.4
add if0
scandone
err,scan status 1
scandone
err,scan status 4
ESP-TOUCH TIMEOUT
Those ssid and pwd can't be known as there is no ESP-TOUCH enabled mobile phones in range.
Can I get rid of ESP-TOUCH in the Mesh?
Postby trojek » Thu Sep 29, 2016 3:46 pm
. In my case it looks: flush ssid:SSID_NAME pwd:PASSWORD. In you case it looks like you don't have any ssid and your password is "strange". I have password in plain text.flush ssid: pwd:@úÿ?@úÿ?
traderlopez
Postby traderlopez » Thu Sep 29, 2016 4:47 pm
If you've set a mobile device for ESP-TOUCH, you forgot to change SSID and PASSWORD to useful values, in the code, so you are seeing the default values.
The values I am being informed are not real, they are rubbish from memory, as they haven't been initialized before they appear logged in the serial port
Thanks very much.
traderlopez
Postby traderlopez » Thu Sep 29, 2016 5:17 pm
I tried to connect the mesh devices and it happens the same.
It wasn't the raspberry pi routing thing, it has something else.
The server is connected, although I think this doesn't make any difference.
This time the user_config.h is:
static const uint8_t server_ip[4] = {192, 168, 0, 100}; /*USER IOT SERVER IP ADDRESS*/
/*MAC OF ROUTER*/
//static const uint8_t MESH_ROUTER_BSSID[6] = {0x00, 0x0B, 0x81, 0x88, 0x63, 0x83}; PI - no va
#define MESH_ROUTER_SSID "NETDEA" /*THE ROUTER SSID*/
#define MESH_ROUTER_PASSWD "rinocero" /*THE ROUTER PASSWORD*/
#define MESH_SSID_PREFIX "DEMOMESA" /*SET THE DEFAULT MESH SSID PREFIX;THE FINAL SSID OF SOFTAP WOULD BE "MESH_SSID_PREFIX_X_YYYYYY"*/
#define MESH_PASSWD "amiantos" /*SET PASSWORD OF SOFTAP FOR EACH MESH NODE*/
And a random device log:
{lESP-TOUCH FLOW INIT...
SC version: V2.5.4
mode : sta(5c:cf:7f:c1:0b:64)
add if0
scandone
err,scan status 1
scandone
err,scan status 4
ESP-TOUCH TIMEOUT
mode : sta(5c:cf:7f:c1:0b:64) + softAP(5e:cf:7f:c1:0b:64)
add if1
bcn 100
scandone
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
mesh_enable_cb
scan-ch:0
scandone
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
mesh_enable_cb
scan-ch:0
scandone
ESP_Alen
Postby ESP_Alen » Thu Sep 29, 2016 5:37 pm
traderlopez wrote:It seems that the problem is related to ESP-TOUCH, which I don't use
SC version: V2.5.4
add if0
scandone
err,scan status 1
scandone
err,scan status 4
ESP-TOUCH TIMEOUT
Yes, if you don't need eep-touch, please disable esp-touch.
ESP_Alen
Postby ESP_Alen » Thu Sep 29, 2016 5:48 pm
traderlopez wrote:Finally I got the router up again and running.
/*MAC OF ROUTER*/
SC version: V2.5.4
add if0
scandone
err,scan status 1
scandone
err,scan status 4
ESP-TOUCH TIMEOUT
add if1
bcn 100
scandone
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
mesh_enable_cb
scan-ch:0
scandone
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
scan-ch:0
scandone
scan-ch:0
scandone
no ap to join
mesh_enable_cb
scan-ch:0
scandone
If you want to switch router, please use eep-touch to push new AP to device.
traderlopez
Postby traderlopez » Thu Sep 29, 2016 6:01 pm
Please tell me another way to get the new router information programmed into the flash. Currently I use user_config.h.
Thanks very much in advance.
Users browsing this forum: No registered users and 287 guests
