Hello everyone!
As the subject states I receive an IPD command after an unexpected tcp connection close on the channel 0 for example. Is it a normal behavior?
+IPD,0,10:#GETSTATE
AT+CIPSEND=0,21
Recv 21 bytes
+IPD,4,11:#CRAFTBOT?
SEND OK
AT+CIPSEND=4,19
Recv 19 bytes
SEND OK
0,CLOSED
+IPD,0,10:#GETSTATE
AT+CIPSEND=0,21
link is not valid
ERROR
0,CLOSED
0,CONNECT
+IPD,0,10:#GETSTATE
AT+CIPSEND=0,21
Recv 21 bytes
SEND OK
+IPD,0,xx after 0,CLOSE
Re: +IPD,0,xx after 0,CLOSE
Postby pratik » Sat Oct 08, 2016 2:36 pm
That should not be normal.
Can you provide information on the SDK version you are using or the output of AT+GMR command?
Also, please describe your setup if possible. How are your devices connected?
Also, what is the time interval between getting 0, CLOSED and +IPD,0 command? Is it in the order of seconds? Or is it in the milliseconds range?
Postby hjani » Tue Oct 11, 2016 4:43 pm
In our config ESP acts as a server listening on port 80 for TCP connections and also it listens for UDP messages which is used to detect machines. The GETSTATE rate is 1 sec and the UDP broadcast message is sent with 2.4 sec rate.
Here is the complete initialization:
ready
AT+RESTORE
ets Jan 8 2013,rst cause:2, boot mode:(3,0)
load 0x40100000, len 31320, room 16
tail 8
chksum 0x69
load 0x3ffe8000, len 2132, room 0
tail 4
chksum 0x44
load 0x3ffe8860, len 7712, room 4
tail 12
chksum 0x11
csum 0x11
îΓ£ ∞pén∞|ré₧~bbllll`îΓ£εÆpéî≥î l`îΓ£εÆpé∞≥î l`îΓ£εÆpéÄ≥î ll`rlÄÉnî₧bbî|îbbÄÆîÄé£Γ£b∞p~ÆnnnΓé£ îbÆénllîÇlîÄ l∞Ä∞lÄαîÉl`Çnⁿî₧bbllÄÆbî₧bblîbrlrl
ready
AT+CWMODE_CUR=3
AT+CWJAP_CUR="PETYA2","wifipassword"
WIFI CONNECTED
WIFI GOT IP
AT+CIFSR
+CIFSR:APIP,"192.168.4.1"
+CIFSR:APMAC,"5e:cf:7f:c0:b5:73"
+CIFSR:STAIP,"192.168.1.21"
+CIFSR:STAMAC,"5c:cf:7f:c0:b5:73"
AT+CWSAP_CUR="CraftBot_RC0A80115","devicepassword",1,4
AT+CIPMUX=1
AT+CIPSERVER=1,80
ATE1
AT+GMR
AT version:1.3.0.0(Jul 14 2016 18:54:01)
SDK version:2.0.0(656edbf)
compile time:Jul 19 2016 18:43:55
AT+CIPSTART=4,"UDP","0",0,80,2
4,CONNECT
ready
AT+RESTORE
tail 8
chksum 0x69
tail 4
chksum 0x44
tail 12
chksum 0x11
csum 0x11
ready
AT+CWMODE_CUR=3
WIFI CONNECTED
WIFI GOT IP
AT+CIFSR
AT+CIPMUX=1
AT+CIPSERVER=1,80
ATE1
AT+GMR
4,CONNECT
Postby pratik » Thu Oct 13, 2016 11:00 am
I tried the same but never got the problem that you are getting.
Are you using an old AT command firmware? I tried with firmware based on the nonOS SDK v.2.0.0
