I met a error when start iot-demo.
the log as blow:
tail 0
chksum 0x8d
tail 12
chksum 0xcf
ho 0 tail 12 room 4
tail 4
chksum 0xcf
csum 0xcf
2nd boot version : 1.2
SPI Speed : 40MHz
SPI Mode : QIO
SPI Flash Size : 4Mbit
jump to run user1
rf cal sector: 123
rf[112] : 00
rf[113] : 00
rf[114] : 01
SDK ver: 2.0.0(656edbf) compiled @ Jul 19 2016 17:58:40
phy ver: 1055, pp ver: 10.2
SDK version:2.0.0(656edbf)
IOT VERSION = v1.0.5t45772(a)
reset reason: 0
LIGHT PARAM: R: 0
LIGHT PARAM: G: 0
LIGHT PARAM: B: 0
LIGHT PARAM: CW: 0
LIGHT PARAM: WW: 0
LIGHT PARAM: P: 1000
malloc:1
prd:1000 r : 0 g: 0 b: 0 cw: 0 ww: 0
free:0
finish
light sleep en
sleep enable,type: 1
PWM version : 00000003
mode : sta(5c:cf:7f:8b:97:f0) + softAP(5e:cf:7f:8b:97:f0)
add if0
add if1
bcn 100
add 1
aid 1
station: 74:e5:0b:99:52:c8 join, AID = 1
len:145
We have a GET request.
webserver's 192.168.4.2:51911 disconnect
len:321
A_dat:0,tot:0,lenght:0
We have a POST request.
webserver's 192.168.4.2:51912 disconnect
len:260
webserver's 192.168.4.2:51913 disconnect
len:260
webserver's 192.168.4.2:51914 disconnect
len:260
webserver's 192.168.4.2:51915 disconnect
len:260
webserver's 192.168.4.2:51916 disconnect
add 2
aid 2
station: f8:23:b2:90:9f:60 join, AID = 2
len:288
A_dat:141,tot:141,lenght:141
[E]sec fd error
[E]sec fd error
[E]sec fd error
[E]sec fd error
[E]sec fd error
[E]sec fd error
[E]sec fd error
[E]sec fd error
After I send the command" curl -X POST -H "Content-Type:application/json" -d '{"Request" :{"Station":{"Connect_Station":{"ssid":"Netcore1702","password":"liuxintai","token":"37ff6cc04f30b1bf37d4c698534c27568c7a81e7"}}}}' http://192.168.4.1/config?command=wifi",As seen "[E]sec fd error" been print through the serial debugging assistant.
by the way,i set the spi size and map as 4096KB(1024KB+1024KB).
So ,my you help me analyze the problem?
[E]sec fd error
Re: [E]sec fd error
Postby yangyang » Sun Oct 09, 2016 9:22 pm
When I change PRIV_PARAM_START_SEC form 0xfc to 0x7C in user_light.h and ESP_PARAM_START_SEC fom fd to 0x7D in user_esp_plantform.h. And change the spi mode in 512+512,4096kb.
the log as blow:
tail 0
chksum 0x8d
tail 12
chksum 0xcf
ho 0 tail 12 room 4
tail 4
chksum 0xcf
csum 0xcf
SPI Speed : 40MHz
SPI Mode : QIO
jump to run user1
rf cal sector: 123
rf[112] : 00
rf[113] : 00
rf[114] : 01
w_flash
reset reason: 0
LIGHT PARAM: R: 33883397
LIGHT PARAM: G: 84148229
LIGHT PARAM: B: 84214789
LIGHT PARAM: CW: -131580
LIGHT PARAM: WW: -521080592
malloc:1
prd:1000 r : 22222 g: 22222 b: 22222 cw: 22222 ww: 22222
free:0
add if0
add if1
bcn 100
finish
add 1
aid 1
len:145
webserver's 192.168.4.2:52773 disconnect
len:321
webserver's 192.168.4.2:52774 disconnect
len:260
webserver's 192.168.4.2:52775 disconnect
len:260
webserver's 192.168.4.2:52776 disconnect
len:260
webserver's 192.168.4.2:52777 disconnect
len:260
webserver's 192.168.4.2:52778 disconnect
len:94
webserver's 192.168.4.2:52788 disconnect
len:94
webserver's 192.168.4.2:52793 disconnect
len:288
webserver's 192.168.4.2:52794 disconnect
scandone
switch to channel 12
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 4
cnt
connected with Netcore1702, channel 12
dhcp client start...
err already associed!
station: 74:e5:0b:99:52:c8 leave, AID = 1
rm 1
add 1
aid 1
ip:192.168.1.10,mask:255.255.255.0,gw:192.168.1.1
host_name = espressif_light_demo
server_name = _espLight._tcp.local
user_esp_platform_dns_found 115.29.202.58
user_esp_platform_connect
len:145
webserver's 192.168.4.2:52797 disconnect
len:321
webserver's 192.168.4.2:52798 disconnect
user_esp_platform_connect_cb
rm 1
bcn 0
del if1
pm open,type:2 0
{"nonce": 1548589168,"path": "/v1/device/activate/", "method": "POST", "body": {"encrypt_method": "PLAIN", "token": "37ff6cc04f30b1bf37d4c698534c27568c7a81e7", "bssid": "5c:cf:7f:8b:97:f0","rom_version":"v1.0.5t45772(a)"}, "meta": {"Authorization": "token "}}
user_esp_platform_sent_cb
user_esp_platform_recv_cb {"status": 403, "result": "failed", "message": "not valid key, Authorization: token AUTH-TOKEN"}
please check device is activated.
{"nonce": 408440173,"path": "/v1/device/activate/", "method": "POST", "body": {"encrypt_method": "PLAIN", "token": "37ff6cc04f30b1bf37d4c698534c27568c7a81e7", "bssid": "5c:cf:7f:8b:97:f0","rom_version":"v1.0.5t45772(a)"}, "meta": {"Authorization": "token "}}
When I Send the command"curl -X POST -H "Content-Type:application/json" -d '{"Request" :{"Station":{"Connect_Station":{"ssid":"Netcore1702","password":"liuxintai","token":"37ff6cc04f30b1bf37d4c698534c27568c7a81e7"}}}}' http://192.168.4.1/config?command=wifi" the message "{"nonce": 1548589168,"path": "/v1/device/activate/", "method": "POST", "body": {"encrypt_method": "PLAIN", "token": "37ff6cc04f30b1bf37d4c698534c27568c7a81e7", "bssid": "5c:cf:7f:8b:97:f0","rom_version":"v1.0.5t45772(a)"}, "meta": {"Authorization": "token "}}
user_esp_platform_recv_cb {"status": 403, "result": "failed", "message": "not valid key, Authorization: token AUTH-TOKEN"}"has been printed.
It probable means the esp8266 load 694ae031991698b605d4571f7ebbb5923b2bbf90.bin(master_device_key.bin) failed.
The flash download message as the img:
the log as blow:
tail 0
chksum 0x8d
tail 12
chksum 0xcf
ho 0 tail 12 room 4
tail 4
chksum 0xcf
csum 0xcf
SPI Speed : 40MHz
SPI Mode : QIO
jump to run user1
rf cal sector: 123
rf[112] : 00
rf[113] : 00
rf[114] : 01
w_flash
reset reason: 0
malloc:1
free:0
add if0
add if1
bcn 100
finish
add 1
aid 1
len:145
len:321
len:260
len:260
len:260
len:260
len:94
len:94
len:288
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 4
cnt
rm 1
add 1
aid 1
len:145
len:321
rm 1
bcn 0
del if1
pm open,type:2 0
Re: [E]sec fd error
Postby ESP_Greg » Tue Oct 11, 2016 7:02 pm
[E]sec fd error means flash write/read issue. Please use latest SDK(NONOS SDK 2.0). Bug already fixed.
