Using > 32Mb (>4MB) flash
piersfinlayson
Postby piersfinlayson » Wed Oct 12, 2016 4:03 am
Is it possible to access > 4MB flash via the non OS SDK?
I've written a test application and can't access flash memory above 0x400000 (sector 0x400) using spi_flash_erase_sector. I have tried with all of the various flash_size_map settings in gen_appbin.py plus some other values, so am guessing the SDK doesn't support > 4MB access.
Thanks,
Piers
ESP_Greg
Re: Using > 32Mb (>4MB) flash
Postby ESP_Greg » Wed Oct 12, 2016 6:16 pm
user_rw_flash_16Mbyte_rtos.c
#include "esp_common.h"
#include "c_types.h"
#include "spi_flash.h"
extern SpiFlashChip flashchip;
#define USER_FLASH_SIZE_BYTE (16*1024*1024)
SpiFlashOpResult user_flash_erase_sector(uint16 sector)
uint32 chipsize = flashchip.chip_size; // backup org chip size
flashchip.chip_size=USER_FLASH_SIZE_BYTE;
uint8 status=0;
status=spi_flash_erase_sector(sector);
flashchip.chip_size = chipsize; // restore chip size
return status;
SpiFlashOpResult user_flash_write(uint32 des_addr, uint32 *src_addr, uint32 size)
uint8 status=0;
status=spi_flash_write(des_addr,src_addr,size);
return status;
SpiFlashOpResult user_flash_read(uint32 src_addr, uint32 *des_addr, uint32 size)
uint8 status=0;
status=spi_flash_read(src_addr,des_addr,size);
return status;
SpiFlashOpResult IRAM_ATTR SPI_block_erase_t(SpiFlashChip * spi, uint32 addr)
Wait_SPI_Idle(spi);
// sector erase 4Kbytes erase is sector erase.
WRITE_PERI_REG(0x60000204, addr & 0xffffff);
WRITE_PERI_REG(0x60000200, BIT23);
while(READ_PERI_REG(0x60000200)!=0);
Wait_SPI_Idle(spi);
return SPI_FLASH_RESULT_OK;
SpiFlashOpResult IRAM_ATTR flash_erase_block(uint32 block_num)
//disable icache
Cache_Read_Disable();
//wait spi idle
Wait_SPI_Idle(&flashchip);
if (block_num>= ((flashchip.chip_size)/(flashchip.block_size)))
{ return SPI_FLASH_RESULT_ERR;
if ( SPI_FLASH_RESULT_OK != SPI_write_enable(&flashchip))
if (SPI_FLASH_RESULT_OK != SPI_block_erase_t(&flashchip, block_num*(flashchip.block_size)))
//enable icache
Cache_Read_Enable_New();
user_flash_erase_block(uint32 block_num)
uint8 status=0;
vPortEnterCritical();
status = flash_erase_block(block_num);
vPortExitCritical();
return status;
user_rw_flash_16Mbyte_rtos.h
SpiFlashOpResult user_flash_erase_sector(uint16 sector);
SpiFlashOpResult user_flash_write(uint32 des_addr, uint32 *src_addr, uint32 size);
SpiFlashOpResult user_flash_read(uint32 src_addr, uint32 *des_addr, uint32 size);
SpiFlashOpResult user_flash_erase_block(uint32 block_num);
piersfinlayson
Postby piersfinlayson » Thu Oct 13, 2016 2:20 am
piersfinlayson
Postby piersfinlayson » Thu Oct 13, 2016 4:11 am
Therefore reading flashchip.chip_size gave 0x1640ef (presumably actually the deviceId, with the 18 for 16MB set to 16 instead). block_size was 0x400000, which was the configured flash chip size (4MB) in byte[3] of the flash. So everything was out by a word.
Once I created my own pointer to _flashchip at 0x3fffc718 and accessed chip_size from here it all started working.
Perhaps the linker line:
PROVIDE ( flashchip = 0x3fffc714);Should actually be:
PROVIDE ( flashchip = 0x3fffc718);?
You can see my test app here:
https://github.com/piersfinlayson/esp-sdk-samples/tree/master/eeprom
piersfinlayson
Postby piersfinlayson » Fri Oct 14, 2016 4:40 am
extern SpiFlashChip *flashchip;
Users browsing this forum: No registered users and 330 guests
