Here is what happens (this was flashed using the esp flash download tool v2,3). On the first boot after flashing the bootloader and blank.bin at 0x7e000 as well as 0x3e000 the bootloader outputs:
tail 0
chksum 0x63
tail 0
chksum 0x02
tail 0
chksum 0x79
csum 0x79
2nd boot version : 1.5
SPI Speed : 40MHz
SPI Mode : QIO
SPI Flash Size & Map: 4Mbit(256KB+256KB)
jump to run user1 @ 1000
error magic!
first boot failed, reboot to try backup bin
wdt reset
tail 0
chksum 0x63
tail 0
chksum 0x02
tail 0
chksum 0x79
csum 0x79
SPI Speed : 40MHz
SPI Mode : QIO
jump to run user2 @ 41000
error magic!
backup boot failed.
user code doneI then reset the esp8266 and here is what happens:
tail 0
chksum 0x63
tail 0
chksum 0x02
tail 0
chksum 0x79
csum 0x79
SPI Speed : 40MHz
SPI Mode : QIO
error magic!
backup boot failed.
user code doneAt this point the bootloader will never again try user1 @0x1000. All this works fine with earlier bootloaders (pre 1.5). It also fails with 1.6.
