Docker: Super easy compiling and flashing without installing the SDK and all the dependencies
NopItTwice
Postby NopItTwice » Tue Oct 25, 2016 3:52 am
For those of you who don't know what Docker is: It allows you to automatically generate containers which are similar to a vm, but use way less resources and can be used like an executable. After you ran it, it simply resets, so you can't break anything.
And the best thing: You don't have to install all the dependencies and the SDK(s). And it just WORKS on pretty much any system.
So I created two docker images: One for the "ESP8266 and ESP8266EX" and one for the "ESP32 and ESP31b".
If you are interested check it out on Github: https://github.com/T-vK/docker-esp-sdk
To build the docker image you just have to install docker and run these three lines:
git clone https://github.com/T-vK/docker-esp-sdk.git
cd docker-esp-sdk
sudo docker build -t tavk/esp-sdk:0.1.0 .
Usage is super simple:
Compiling binaries
sudo docker run -t -i -u esp \
-v /home/ubuntu/esp8266/esp-open-sdk/examples/blinky:/home/esp/shared_project \
-e SDK_VERSION='1.5.3' \
tavk/esp-sdk:0.1.0 \
make
Flashing binaries
--device=/dev/ttyUSB0 \
esptool.py --port /dev/ttyUSB0 write_flash 0x00000 blinky-0x00000.bin 0x40000 blinky-0x40000.bin
Flashing bootloaders
-v /home/ubuntu/projects/esp-bootloader:/home/esp/shared_project \
esptool.py --port /dev/ttyUSB0 write_flash --flash_mode dio --flash_size 32m 0x0 bootloader.bin
More detailed info on Github:
electronicsguy
Re: Docker: Super easy compiling and flashing without installing the SDK and all the dependencies
Postby electronicsguy » Tue Jan 31, 2017 9:49 pm
If I only do development on my own Linux machine, is there still any advantage of using Docker over locally installing the tool-chain?
Users browsing this forum: No registered users and 304 guests
