ESP8266 Smart config mode.
Postby suresh » Thu Oct 27, 2016 5:02 pm
My requirement is as follows:
ESP8266 devices should form a mesh network. The root ESP8266 device should hook to a WiFi router. A server (an Android app) connected to the same WiFi router must be able to send commands to control each ESP8266 device.
After going through the help docs and demos, I could successfully run the mesh demo by updating user_config.h with my router's SSID and password.
Now I need the mesh_demo to work in smart config mode so that I can use ESP_Touch Android App to supply SSID and password to the ESP device. What configuration change do I need to make in mesh_demo source code to enable smart config?
Please guide me.
Suresh
Please guide me.
Suresh
ESP_Alen
Re: ESP8266 Smart config mode.
Postby ESP_Alen » Wed Nov 02, 2016 10:08 pm
suresh wrote:If anyone knows why ESP-TIMEOUT is happening without even waiting for a second, please help me.
Please setup time for esp-touch.
* while system runs smartconfig (STA mode), mesh (STA + SoftAp mode) must not been enabled,
* So wait for esptouch to run over and then execute espconn_mesh_enable
os_timer_t *wait_timer = (os_timer_t *)os_zalloc(sizeof(os_timer_t));
if (NULL == wait_timer) return;
os_timer_disarm(wait_timer);
os_timer_setfn(wait_timer, (os_timer_func_t *)wait_esptouch_over, wait_timer);
os_timer_arm(wait_timer, 30000, true);
Postby suresh » Wed Nov 09, 2016 5:21 pm
Hi Alen,
Increased the timeout as per your advice. But no effect. ESP-TOUCH TIMEOUT appears immediately after the boot!
Following is my user_init routine:
void user_init(void)
* set uart baut ratio
uart_div_modify(0, UART_CLK_FREQ / UART_BAUD_RATIO);
uart_div_modify(1, UART_CLK_FREQ / UART_BAUD_RATIO);
MESH_DEMO_PRINT("user_init");
if (!router_init()) {
return;
if (!esp_mesh_demo_init())
return;
user_devicefind_init();
return;
return;
Postby suresh » Wed Nov 09, 2016 8:43 pm
Changed the following timer value from 2000 to 20000 and it works now! Thank you Alen
#define ESP_TOUCH_TIME_ENTER (20000) /*Time limit for ESP-TOUCH to receive config packets*/
ESP_Alen
Postby ESP_Alen » Mon Dec 05, 2016 10:41 am
suresh wrote:Changed the following timer value from 2000 to 20000 and it works now! Thank you Alen
welcome.
