In order to install NONOS 2.0.0 on 4Mbi flash; I am using the following settings
http://i68.tinypic.com/17e72d.png
However, I am only able to update flash but the module doesn’t respond to AT commands(when sent AT, I don’t get OK back. Other commands doesn’t work either).
Please advice if the settings are correct also the address are correct?
Flash is: at25sf041
Date sheet: https://www.adestotech.com/wp-content/u ... 41_044.pdf
Thank you,
Regdards
