AT+PING on the same URL works but AT+CIPSEND fails with CLOSED SEND FAIL message.
Can some one look at the code attached and help me know what I am doing wrong here?
#include <SoftwareSerial.h>
SoftwareSerial ESP8266_Response(2,3);
#define DEBUG true
//AT+UART_DEF=9600,8,1,0,0
void setup() {
ESP8266_Response.begin(9600);
Serial.begin(9600);
String s1="";
s1=sendCommand("AT\r\n",2000,DEBUG);
Serial.print(s1);
s1=sendCommand("AT+RST\r\n",2000,DEBUG);
Serial.print(s1);
s1= sendCommand("ATE0\r\n",2000,DEBUG);
Serial.print(s1);
s1=sendCommand("AT+CWMODE=1\r\n",2000,DEBUG);
Serial.print(s1);
s1=sendCommand("AT+CWJAP=\"Satyam\",\"vivekvpandya\"\r\n",5000,DEBUG);
Serial.print(s1);
sendCommand("AT+CIPMUX=0\r\n",3000,DEBUG);
sendCommand("AT+CIFSR\r\n",3000,DEBUG);
String siteResp=sendCommand("AT+CIPSTART=\"TCP\",\"dev-pdemo.pantheonsite.io\",80\r\n",5000,DEBUG);
Serial.print(siteResp);
String cmd = "GET /dustbin_list HTTP/1.1\r\nHost:dev-pdemo.pantheonsite.io\r\n\r\n";
ESP8266_Response.print("AT+CIPSEND=");
ESP8266_Response.println(cmd.length());
delay(8000);
if(ESP8266_Response.find(">"))
String s2 = sendCommand(cmd,5000,DEBUG);
Serial.print(s2);
} else {
Serial.print("Could not find >");
void loop()
String sendCommand(String command, const int timeout, boolean debug)
String response = "";
ESP8266_Response.print(command); // send the read character to the esp8266
long int time = millis();
while( (time+timeout) > millis())
while(ESP8266_Response.available())
char c = ESP8266_Response.read(); // read the next character.
response+=c;
return response;
}Thanks,
Vivek
