Start wifi network after force sleep
rith87
Postby rith87 » Thu Nov 03, 2016 11:13 am
I'm having difficulty trying to start a wifi network after a force sleep. Specifically, I'm trying the following sequence of events:
1. Sleep wifi
    wifi_set_opmode(NULL_MODE);
    wifi_fpm_set_sleep_type(MODEM_SLEEP_T);
    wifi_fpm_open();
    wifi_fpm_do_sleep(FPM_SLEEP_MAX_TIME);
2. Wake up wifi
    wifi_fpm_do_wakeup();
    wifi_fpm_close();
ESP returns:
fpm wk err: pm is open
fpm close 3
3. Start wifi network
ESP returns:
mode : sta(5c:cf:7f:16:59:b6) + softAP(5e:cf:7f:16:59:b6)
add if0
add if1
bcn 100
However, the callback from wifi_set_event_handler_cb() is never called. And the ESP does not host the wifi network. Also, even if I add a system_restart() between (2) and (3), the ESP still fails to host the wifi network. The ESP hosts the wifi network fine if the force sleep code is omitted on a hard reset.
Any ideas?
