I am using Huzzah as development platform. I installed AT command firmware from SDK 2.0.0.
My command set is simple:
AT+CWMODE_CUR=1
AT+CWJAP_CUR="bitoad","ropuchabi2"
AT+SLEEP=1
I have found that after AT+SLEEP=1 ESP is less responsible then without it.
I need to try AT\r\n several time to trigger OK. ESP ignores that commands and react after 2-6 retries.
I am testing on FTDI with Rx/Tx/VCC/GND connected on Putty and terminal emulator on Mac.
Is it normal behavior? Why?
Thank you in advance for help.
Best regards
[SOLVED] Strange behavior after AT+SLEEP=1
Re: Strange behavior after AT+SLEEP=1
Postby pratik » Thu Nov 10, 2016 1:06 pm
The ESP8266 shuts down internal clocks to save power. Please use a GPIO trigger to wake the chip up from light sleep before resuming with operations. Try AT+WAKEUPGPIO command before sleep mode.
Also, take a look at the attached guide to understand sleep modes better.
- Attachments
- 9b-esp8266_sleep_function_description_en_v1.0.pdf
- (322.73 KiB) Downloaded 749 times
Postby kelcon » Thu Nov 24, 2016 11:39 pm
It helped. Thank you.
Best regards!
Best regards!
