Unexpected error code after AT+CWJAP_CUR with an incorrect password.
yamazaki
Postby yamazaki » Mon Nov 14, 2016 5:17 pm
Currently I’m testing with NONOS_SDK_V2.0.0 (including patch).
However one difference is observed between 1.5.1 and 2.0.0 as following.
I sent AT+CWJAP_CUR with a correct SID and an incorrect password, but replied error code from esp8266 is “1: connection timeout”.
AT+CWJAP_CUR="APxxx","pass1234"
WIFI DISCONNECT
+CWJAP:1
FAIL
In the same test case with 1.5.1, esp8266 replies Error code “2: wrong password” expectedly.
AT+CWJAP_CUR=" APxxx "," passw1234"
WIFI DISCONNECT
+CWJAP:2
FAIL
Could someone tell me why the difference is observed and also tell me how to avoid the issue?
Thanks in advance for your help!
ESP_Xutao
Re: Unexpected error code after AT+CWJAP_CUR with an incorrect password.
Postby ESP_Xutao » Mon Dec 05, 2016 5:23 pm
Hi:
Before you conifg wifi(AT+CWJAP),you can user AT+CWMODE=1 or AT+CWMODE=3.Module wifi mode is station.
yamazaki
Postby yamazaki » Tue Dec 06, 2016 7:01 pm
Hi Xutao-san,
Thank you for the comment.
But I always send "AT+CWMODE=1" before "AT+CWJAP_CUR" as you described.
