Watchdog failed to reset esp properly
gailu
Postby gailu » Wed Nov 23, 2016 6:05 pm
Hi Experts,
We are doing regression testing of our software running on ESP-12 with SDK 2.0 (ESP8266_NONOS_SDK_V2.0.0_16_07_19). When generating lots of interrupts and TCP communication we see that Watchdog is kicked in which is expected. However we are facing an issue approx once out of 6-7 attempts where Watchdog is kicked-in but board is not reset properly and remains in hanged position.
When Watchdog resets the board properly wee see following logs at console.
ets Jan  8 2013,rst cause:4, boot mode:(3,7)
wdt reset
tail 8
chksum 0xe5
tail 8
chksum 0x84
tail 8
chksum 0xd8
csum 0xd8
Occasionally when watchdog is kicked in but board is not reset properly we see only following prints on console.
ets Jan  8 2013,rst cause:4, boot mode:(2,7)
wdt reset
;[1E]ts_main.c
Can you please let me know what could be the reason where watchdog is not able to reset the board as expected.
Can someone please explain the difference between boot mode (3,7) in successful case and (2,7) in failure case. Any documentation on boot mode please?
Also please let me know the meaning of "[1E]ts_main.c" print
Re: Watchdog failed to reset esp properly
Postby pratik » Sun Nov 27, 2016 1:38 pm
Please make sure that the boot mode GPIOs are in a valid state when the reset occurs!
No external circuitry shoulld be driving those pins to value = 2, which may cause this issue.
Users browsing this forum: No registered users and 301 guests
