ESP8266 Reset because of gpio pin toggle?
Stational
Postby Stational » Fri Nov 25, 2016 5:35 am
my esp8266 resets (probably) because i toggle some pins quite fast with this function:
void pinHigh(uint32_t PIN){
   gpio_output_set(0,0,0,PIN);
void pinLow(uint32_t PIN){
   gpio_output_set(0,PIN,PIN,0);
void sendByte(uint8_t dataByte){
   uint8_t initBitCounter;
   for(initBitCounter = 7; initBitCounter >= 0; initBitCounter--){
      uint8_t bitToWrite = (dataByte >> initBitCounter) & 1;
      if(bitToWrite == 1){
         pinHigh(SDI);
      } else {
         pinLow(SDI);
      pinHigh(SCK);
      os_delay_us(2);
      pinLow(SCK);
I call the "sendByte" - function every second with a timer, the esp8266 resets every ~4 seconds. Why is that?
Re: ESP8266 Reset because of gpio pin toggle?
Postby pratik » Fri Nov 25, 2016 2:04 pm
What type of reset are you mentioning here? It would help to see the reset debug output log!
Stational
Postby Stational » Fri Nov 25, 2016 3:32 pm
Thanks for your reply,
i don't know how this reset is called, it just stops working after ~4s and then i get this message on my serial monitor (74480 Baud):
SDK ver: 1.5.4(baaeaebb) compiled @ May 17 2016 19:23:54
phy ver: 972, pp ver: 10.1
mode : sta(5c:cf:7f:1c:0a:10)
¢@*r…Ä(±±Kít¥dmXK
nzAl
±#Nørf[112] : 03
rf[113] : 00
rf[114] : 01
Then it works again for 4 seconds...
Postby pratik » Sun Nov 27, 2016 1:23 pm
Can you please attach all the BIN files here... what you are trying to flash and it causes errors? I can take a look then!
Stational
Postby Stational » Sat Dec 03, 2016 5:33 am
It looks like it is not allowed to attach .bin files in this forum. I uploaded the files to an external website:
http://workupload.com/archive/USnQLLh
