Hi Espressif,
What might be the causes of "ESPCONN_IF" returned by espconn_sendto() to send UDP data, and how to fix it or handle it?
sdk: 1.5.4 NON-OS
Here below is the reproduction scenario:
1. We call espconn_sendto() to continuously send udp packet of 1024 bytes as below:
(1) espconn_sendto() to send a packet of 1024 bytes to an existing ip address of the same LAN;
(2) wait espconn_sent_callback() called, or wait more than 1ms using timer
(3) go to (1) to repeat
2. However, we found via debug info that, we could repeat only tens of times, then the espconn_sent_callback() will not
be called and no data will be sent out, while espconn_sendto() will return -14, that is "ESPCONN_IF" error.
3. The first tens of packets in 1024 bytes each have been sent out succesfully and received by the UDP peer successfully.
4. If we call espconn_sendto() sending to a "fake" (not present) ip addiress, the espconn_sendto() always return successfully,
no "ESPCONN_IF" error will returned.
What makes differences here between 2 and 4?
5. If we give some delay after every 8 packets have been sent out as above 1, then there will be no "ESPCONN_IF" error as well.
However, this slowdown the throughout we don't expected.
Would you please kindly give us some hints to fix it here?
Thanks in advance!
Yiming Li
What might be the causes of "ESPCONN_IF" error?
YimingLi
YimingLi
Re: What might be the causes of "ESPCONN_IF" error?
Postby YimingLi » Wed Dec 07, 2016 12:02 am
Can Anyone give some hints here?!
Yiming
Yiming
Users browsing this forum: No registered users and 287 guests
