ESP8266 sends TCP packets continuously
Postby ESP_Faye » Wed Apr 01, 2015 11:29 am
:idea: :idea: :idea:
If using espconn in ESP8266_RTOS_SDK, please call espconn_init in user_init as initialization.
Sample code below is based on ESP8266_NONOS_SDK.
We suggest to call the next espconn_send in espconn_sent_callback which means that the previous packet is sent.
Or users could enable the espconn_write_finish_callback which means the data sending by espconn_send was written into the write-buffer or already sent, and call the next espconn_send in espconn_write_finish_callback.
The write-buffer can store 8 packets at most, waiting for the TCP ACK. The size of write-buffer is 2920 bytes.
Introduce an API here:
Function: Set option of TCP connection
Prototype:
sint8 espconn_set_opt(
        struct espconn *espconn,
        uint8 opt
Parameter:
struct espconn *espconn : corresponding connected control structure
uint8 opt : Option of TCP connection
bit 0: 1: free memory after TCP disconnection happen need not wait 2 minutes;
bit 1: 1: disable nalgo algorithm during TCP data transmission, quiken the data transmission.
bit 2: 1: enable espconn_write_finish_callback.
bit 3: 1: enable TCP keep-alive function
Return:
0      : succeed
Non-0  : error (please refer to espconn.h for details.)
   e.g. ESPCONN_ARG: illegal argument,can’t find TCP connection according to structure espconn
Note:
In general, we need not call this API;
If call espconn_set_opt, please call it in TCP connected callback.
Sample code of send TCP data continually is as bellow
1. call espconn_set_opt to enable write buffer;
2. register a write finish callback;
3. send next packet in write finish callback.
LOCAL os_timer_t test_timer;
LOCAL struct espconn user_tcp_conn;
LOCAL struct _esp_tcp user_tcp;
ip_addr_t tcp_server_ip;
 * FunctionName : user_tcp_recv_cb
 * Description  : receive callback.
 * Parameters   : arg -- Additional argument to pass to the callback function
 * Returns      : none
LOCAL void ICACHE_FLASH_ATTR
user_tcp_recv_cb(void *arg, char *pusrdata, unsigned short length)
   //received some data from tcp connection
    os_printf("tcp recv !!! %s \r\n", pusrdata);
 * FunctionName : user_tcp_sent_cb
 * Description  : data sent callback.
 * Returns      : none
user_tcp_sent_cb(void *arg)
   //data sent successfully
 * FunctionName : user_tcp_discon_cb
 * Description  : disconnect callback.
 * Returns      : none
user_tcp_discon_cb(void *arg)
   //tcp disconnect successfully
    os_printf("tcp disconnect succeed !!! \r\n");
 * FunctionName : user_tcp_write_finish
 * Description  : Data need to be sent by espconn_sent has been written into write buffer successfully,
                         call espconn_sent to send next packet is allowed.
 * Parameters   : pespconn -- the espconn used to connetion with the host
 * Returns      : none
user_tcp_write_finish(void *arg)
    espconn_sent(pespconn, "Hello World!", 12);
 * FunctionName : user_sent_data
 * Description  : Processing the application data and sending it to the host
 * Returns      : none
user_sent_data(struct espconn *pespconn)
 * FunctionName : user_tcp_connect_cb
 * Description  : A new incoming tcp connection has been connected.
 * Returns      : none
user_tcp_connect_cb(void *arg)
    os_printf("connect succeed !!! \r\n");
    espconn_regist_recvcb(pespconn, user_tcp_recv_cb);
    espconn_regist_sentcb(pespconn, user_tcp_sent_cb);
    espconn_regist_disconcb(pespconn, user_tcp_discon_cb);
    espconn_set_opt(pespconn, 0x04); // enable write buffer
    espconn_regist_write_finish(pespconn, user_tcp_write_finish); // register write finish callback
    user_sent_data(pespconn);
 * FunctionName : user_tcp_recon_cb
 * Description  : reconnect callback, error occured in TCP connection.
 * Returns      : none
user_tcp_recon_cb(void *arg, sint8 err)
   //error occured , tcp connection broke. user can try to reconnect here.
    os_printf("reconnect callback, error code %d !!! \r\n",err);
 * FunctionName : user_check_ip
 * Description  : check whether get ip addr or not
 * Parameters   : none
 * Returns      : none
user_check_ip(void)
    struct ip_info ipconfig;
   //disarm timer first
    os_timer_disarm(&test_timer);
   //get ip info of ESP8266 station
    if (wifi_station_get_connect_status() == STATION_GOT_IP && ipconfig.ip.addr != 0)
      os_printf("got ip !!! \r\n");
      // Connect to tcp server as NET_DOMAIN
      user_tcp_conn.proto.tcp = &user_tcp;
      user_tcp_conn.type = ESPCONN_TCP;
      user_tcp_conn.state = ESPCONN_NONE;
      const char esp_server_ip[4] = {X, X, X, X}; // remote IP of tcp server
      os_memcpy(user_tcp_conn.proto.tcp->remote_ip, esp_server_ip, 4); // remote ip of tcp server
      user_tcp_conn.proto.tcp->remote_port = TCP_SERVER_PORT; // remote port of tcp server
      user_tcp_conn.proto.tcp->local_port = espconn_port(); //local port of ESP8266
      espconn_regist_connectcb(&user_tcp_conn, user_tcp_connect_cb); // register connect callback
      espconn_regist_reconcb(&user_tcp_conn, user_tcp_recon_cb); // register reconnect callback as error handler
      espconn_connect(&user_tcp_conn); // tcp connect
   else
        if ((wifi_station_get_connect_status() == STATION_WRONG_PASSWORD ||
                wifi_station_get_connect_status() == STATION_NO_AP_FOUND ||
                wifi_station_get_connect_status() == STATION_CONNECT_FAIL))
         os_printf("connect fail !!! \r\n");
      else
           //re-arm timer to check ip
            os_timer_setfn(&test_timer, (os_timer_func_t *)user_check_ip, NULL);
            os_timer_arm(&test_timer, 100, 0);
 * FunctionName : user_set_station_config
 * Description  : set the router info which ESP8266 station will connect to
 * Parameters   : none
 * Returns      : none
user_set_station_config(void)
   // Wifi configuration
   char ssid[32] = "SSID";
   char password[64] = "PASSWORD";
   //need not mac address
   stationConf.bssid_set = 0;
   //Set ap settings
   //set a timer to check whether got ip from router succeed or not.
 * FunctionName : user_init
 * Parameters   : none
 * Returns      : none
void user_init(void)
   //Set softAP + station mode
   //ESP8266 connect to router
   user_set_station_config();
Tiffany
Re: ESP8266 sends TCP packets continuously
Postby Tiffany » Wed Aug 23, 2017 4:38 pm
请问它能连续发多少次?一直发下去么。Can the packets be sent with no stopping?Or how many times in this code
Tiffany
Postby Tiffany » Wed Aug 23, 2017 5:15 pm
我用2秒的间隔发心跳,发了12次
Postby Her Mary » Sat Sep 30, 2017 6:48 pm
能顺畅发多少数据,主要还是看网络状况的,如果网络通畅,一直发都没问题。
如果网络堵塞,等底层缓存等待发送的 buffer 满了,还是会提示发送失败。
WarnerBoisa
Postby WarnerBoisa » Sun Jan 13, 2019 5:51 pm
I never mentioned that some packets were lost, just that the size of the packets can be different as shown by the sniffer and the client I used. I am not trying to accuse you of any mistake I just try to understand why the length of the packet I get are different and if I can still use them. I guess that by buffering you mean that I should concatenate the data I receive in a buffer, which partly answers my message. Still no idea about the ACK message send only 1/3 times ?
aresgerardo
Postby aresgerardo » Mon Aug 24, 2020 12:43 pm
It should be noted that the version of Python interpreter used should be invoked when using ESP8266_RTOS_SDK, the command that shows you the version is python --version and you might want to use python2, python2.7 or similar instead of python simple. Another thing to remember is that there should be no spaces in paths to ESP8266_RTOS_SDK or to projects. A simple configuration cutfullprice for wifi might contain something like:
menu "Example Configuration"
choice EXAMPLE_WPS_TYPE
prompt "WPS mode"
default EXAMPLE_WPS_TYPE_PBC
help
WPS type for the esp8266 to use.
config EXAMPLE_WPS_TYPE_PBC
bool "PBC"
config EXAMPLE_WPS_TYPE_PIN
bool "PIN"
config EXAMPLE_WPS_TYPE_DISABLE
bool "disable"
endchoice
endmenu
