espconn_mesh_disconnect does not close tcp connection
0xfa1c0
Postby 0xfa1c0 » Sun Jan 01, 2017 5:11 pm
Hi all, in my project I have a mesh and a tcp server that sink the data from the sensor network. The sensor network form a mesh and establish the tcp connection with the server using
espconn_mesh_enable(mesh_enable_cb, MESH_ONLINE);
, then each device sends data through
espconn_mesh_sent
function.
The behaviour that I would expect is that once sent the data, the device disconnects from the server closing the TCP connection, to do this I call
, but it doesn't close the tcp connection, there is any other command? Thank you
ESP_Xutao
Re: espconn_mesh_disconnect does not close tcp connection
Postby ESP_Xutao » Wed Jan 04, 2017 11:42 am
hi:
Do not call this API in any espconn callback. If needed, please use system task to trigger espconn_mesh_ disconnect.you can consult mesh_api document:http://espressif.com/sites/default/files/documentation/30a-esp8266_nonos_mesh_api_reference_v1.0.0_20160203.pdf
0xfa1c0
Postby 0xfa1c0 » Fri Jan 06, 2017 1:30 am
Can I call it from a timer callback?
Users browsing this forum: No registered users and 313 guests
