Unknown answer +CWMODE_CUR:(1-3) did I discover a new ESP8266 variation
serge
Postby serge » Fri Jan 06, 2017 10:41 pm
New to try ESP8266 and on this forum
Here the status of communication after initial AT+RST and received all text information
WIFI DISCONNECT !!!!!
AT+GMR
SDK version:1.3.0
Ai-Thinker Technology Co.,Ltd.
Build:1.3.0.2 Sep 11 2015 11:48:04
AT+CIPSTATUS
STATUS:5 5 : Wi-Fi connection fail
AT+CWJAP?
No AP
AT+CIFSR
+CIFSR:APIP,"192.168.4.1"
+CIFSR:APMAC,"1a:fe:34:d7:bb:92"
+CIFSR:STAIP,"0.0.0.0"
+CIFSR:STAMAC,"18:fe:34:d7:bb:92"
AT+CWJAP_CUR ="TNCAPA13F8D","xxxxxxxxxxxxx"
ERROR
AT+CWMODE?
+CWMODE:3
AT+CWMODE_CUR=?
+CWMODE_CUR:(1-3) !!!!!!!!!!!!!!!
AT+CWDHCP?
+CWDHCP:3
What does that mean +CWMODE_CUR:(1-3) and what would be the solution to go on, testing this product?
Serge
ESP_Xutao
Re: Unknown answer +CWMODE_CUR:(1-3) did I discover a new ESP8266 variation
Postby ESP_Xutao » Mon Jan 09, 2017 3:27 pm
Hi
AT+CWMODE_CUR,this command is set wifi work mode,for example:AT+CWMODE_CUR=1,this is station mode.If you want connect wifi,you should set station mode.you can consult AT example document. http://espressif.com/sites/default/file ... les_en.pdf
serge
Postby serge » Mon Jan 09, 2017 7:02 pm
Thanks for answer.
Has I did not succed to connect as a station I did not well understand what the answer means
After a AT+RESTORE, I succedded to connect and set the different modes:
After AT+RST:
ready
WIFI CONNECTED
WIFI GOT IP
