I'm writing an OTA Application on which I first download the new application over a special protocoll, write the downloaded chunks to a seperate section of the flash and then copy them over to the main flash (0x10000...). But I have a problem on erasing the flash. After trying to erase Sector 16 (0x10000) the ESP stops working. The function which erases the flash is allocated in the RAM ( #define IRAM_ATTR __attribute__((section(".text"))) )
I'm using the NONOS V2.0
The code is the following:
void IRAM_ATTR kiloota_move_flash(void) {
unsigned char data_rewrite[4096];
os_printf("Now flashing the SW\n");
ets_wdt_disable();
uint32_t flashsize;
for(flashsize = 0; flashsize <= file_bytes; flashsize = flashsize+4096) {
os_printf("Read data from FLASH\n");
spi_flash_read(flash_start + flashsize, (uint32 *) data_rewrite, 4096);
os_printf("Erasing Sector on FLASH, Position %d, Sector %d\n", 0x10000 + flashsize, (0x10000 + flashsize)/4096);
spi_flash_erase_sector((0x10000 + flashsize)/4096);
os_printf("Writing data to FLASH\n");
spi_flash_write(0x10000 + flash_start, (uint32 *) data_rewrite, 4096);
ets_wdt_enable();
system_restart();
}Code: Select all
Now flashing the SW
Erasing Sector on FLASH, Position 65536, Sector 16Any idea?
