Problem with AT+CIPSTART don't connect, say: ERROR CLOSE
Postby CharlyC64 » Tue Jan 17, 2017 3:03 pm
Hi everyone!
I tried with different firmwares and I got always the same response. I needs help to connect to one socket, please somebody know what is happen?
The socket is open, I tried connect via telnet and all was right but I never can connect with my ESP01
To download the firmware I used:
esptool.py --port /dev/ttyUSB0 write_flash 0x00000 boot_v1.6.bin 0x01000 at/512+512/user1.1024.new.2.bin 0x7e000 blank.bin 0x1fe000 blank.bin
I following this steps to connect to the TCP socket:
AT
AT+RST
tail 8
chksum 0xe5
tail 8
chksum 0x84
tail 8
chksum 0xd8
csum 0xd8
2nd boot version : 1.6
SPI Speed : 40MHz
SPI Mode : QIO
SPI Flash Size & Map: 4Mbit(256KB+256KB)
jump to run user1 @ 1000
����o�{��N|�l�l`��s�p��l��l ��{�$���d ��r�l����$`{$��o����B��c�"c�{�lܜpb��N�2oN��c��N$l�l��$��d���$`�N���bbl$��#���c#$�crlsd
ready
AT+CWMODE=3
AT+CIPMUX=0
AT+CWJAP="SSID","PASSWORD"
WIFI CONNECTED
WIFI GOT IP
AT+CIFSR
+CIFSR:APIP,"192.168.4.1"
+CIFSR:APMAC,"06:00:00:00:06:00"
+CIFSR:STAIP,"8.0.0.0"
+CIFSR:STAMAC,"0c:02:0d:f0:0c:02"
AT+CIPSTART="TCP","54.108.131.123",3000
ERROR
CLOSED
AT
AT+RST
tail 8
chksum 0xe5
tail 8
chksum 0x84
tail 8
chksum 0xd8
csum 0xd8
SPI Speed : 40MHz
SPI Mode : QIO
ready
AT+CWMODE=3
AT+CIPMUX=0
WIFI CONNECTED
WIFI GOT IP
AT+CIFSR
ERROR
CLOSED
Re: Problem with AT+CIPSTART don't connect, say: ERROR CLOSE
Postby ESP_puff » Wed Jan 18, 2017 11:13 am
Hi CharlyC64,
Please check whether you have started such a TCP server waiting for connection.
TCP client should connect the same AP with TCP server. Station AP that ESP8266 get is 8.0.0.0. That is a quite stranger IP address. So you cannot make TCP connection with 54.108.131.123. If you want to make TCP connection with 54.108.131.123, the station IP should be 54.108.xx.xx
Espressif
Puff
FAE
Puff
FAE
Postby CharlyC64 » Wed Jan 18, 2017 7:59 pm
ESP_puff wrote:Hi CharlyC64,
Hi ESP_puff!
The TCP server (a public machin on internet) and client (the ESP8266) are both connected to internet.
The last year I use the same firmware, you could find on my github: https://github.com/devtodev/gatewaywifi and worked fine, but now don't works and I don't know why.
Those AT+Commands works for you when you tring to connect a socket TCP on internet?
Postby ESP_puff » Thu Jan 19, 2017 10:05 am
Hi CharlyC64,
This is the log information that you get
AT+CIFSR
From it, STAIP is 8.0.0.0 that is not correct. You should check why that happen.
AT+CIFSR
Espressif
Puff
FAE
Puff
FAE
