AttachInterrupt on NodeMCU
pxlstuermer
Postby pxlstuermer » Wed Jan 18, 2017 10:50 pm
I'm trying to figure out how the AttachedInterrupt works on the NodeMCU.
Everything I found tells me that this code is OK?!
void setup() {
  Serial.begin(9600);
  pinMode(D4, INPUT);
  attachInterrupt(D4, doSth(), CHANGE);
void loop() {
  Serial.println(digitalRead(D4));
  delay(100);
void doSth() {
  Serial.println("Check!");
But I just get this error:
I still have no idea after hours of research!
Thanks a lot in advance :-)
Tercero
Re: AttachInterrupt on NodeMCU
Postby Tercero » Fri Mar 24, 2017 5:53 pm
attachInterrupt expect a pointer to the function, not its returned value. If you call doSth(), you get the returned value, in your case, it's a void.
Try to remove the parenthesis after doSth:
attachInterrupt(D4, doSth, CHANGE);
