question about macro "ICACHE_RODATA_ATTR"
spiderweb
Postby spiderweb » Fri Jan 27, 2017 11:03 am
My code crashed when i using the macro "ICACHE_RODATA_ATTR",why,thank U very much!
const char ICACHE_RODATA_ATTR  testFlashStr[]="test string";
const int ICACHE_RODATA_ATTR   testFlashArray[]={0,1,2,3,4,5,6,7,8,9};
void testDataInFlash()
   int i=0;
   while(1)
      printf("%u:%s--%d\n",i++,testFlashStr,testFlashArray[i%10]);
      vTaskDelay(1000 / portTICK_RATE_MS);
the uart print:
Fatal exception (3):
epc1=0x40101277
epc2=0x00000000
epc3=0x00000000
epcvaddr=0x4024c038
depc=0x00000000
But,removed the macro "ICACHE_RODATA_ATTR",like this:
const char testFlashStr[]="test string";
const int testFlashArray[]={0,1,2,3,4,5,6,7,8,9};
   int i=0;
   while(1)
It's OK,I was confused
ESP_Xutao
Re: question about macro "ICACHE_RODATA_ATTR"
Postby ESP_Xutao » Mon Feb 06, 2017 10:42 am
hi
For ESP8266_RTOS SDK:
Functions are located in the IROM section by default and do not need to be attributed with ICACHE_FLASH_ATTR. Interrupt handlers can also run from IROM. Hence, if functions called frequently need to be run from IRAM, they should be attributed with IRAM_ATTR.
Users browsing this forum: No registered users and 303 guests
