I'm using mbedtls to connect to aws iot, but I'm not able to compile the code since the mbedtls is missing some defines..
I'm using the original libmbedtls.a from the ESP8266_RTOS_SDK 1.5, I tried to edit the config.h but it dosen't matter, I really need the source code of mbedtls to re-compile it using the necessary config.
/root/esp-open-sdk/ESP8266_RTOS_SDK/lib/libmbedtls.a(ssl_tls.o):(.text.mbedtls_ssl_fetch_input+0x4): undefined reference to `max_content_len'This is the correct config.h:
#ifndef MBEDTLS_CONFIG_H
#define MBEDTLS_CONFIG_H
/* System support */
#define MBEDTLS_HAVE_ASM
#define MBEDTLS_DEPRECATED_WARNING
#define MBEDTLS_ENTROPY_HARDWARE_ALT
#define MBEDTLS_NO_PLATFORM_ENTROPY
/* mbed TLS feature support */
#define MBEDTLS_ECP_DP_SECP256R1_ENABLED
#define MBEDTLS_ECP_DP_SECP384R1_ENABLED
#define MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA_ENABLED
#define MBEDTLS_SSL_PROTO_TLS1_2
/* Debug support (optional) */
// #define MBEDTLS_ERROR_C
// #define MBEDTLS_DEBUG_C
/* mbed TLS modules */
#define MBEDTLS_AES_C
#define MBEDTLS_ASN1_PARSE_C
#define MBEDTLS_ASN1_WRITE_C
#define MBEDTLS_BIGNUM_C
#define MBEDTLS_CIPHER_C
#define MBEDTLS_CTR_DRBG_C
#define MBEDTLS_ECDH_C
#define MBEDTLS_ECDSA_C
#define MBEDTLS_ECP_C
#define MBEDTLS_ENTROPY_C
#define MBEDTLS_GCM_C
#define MBEDTLS_MD_C
#define MBEDTLS_NET_C
#define MBEDTLS_OID_C
#define MBEDTLS_PK_C
#define MBEDTLS_PK_PARSE_C
#define MBEDTLS_SHA256_C
#define MBEDTLS_SHA512_C
#define MBEDTLS_SSL_CLI_C
#define MBEDTLS_SSL_SRV_C
#define MBEDTLS_SSL_TLS_C
#define MBEDTLS_X509_CRT_PARSE_C
#define MBEDTLS_X509_USE_C
/* For verify RSA based root CA certificate (optional if root CA cert is signed using ECC) */
#define MBEDTLS_RSA_C
#define MBEDTLS_SHA1_C
#define MBEDTLS_PKCS1_V15
#define MBEDTLS_PKCS1_V21
/* For test certificates */
#define MBEDTLS_BASE64_C
#define MBEDTLS_CERTS_C
#define MBEDTLS_PEM_PARSE_C
/* Save RAM at the expense of ROM */
#define MBEDTLS_AES_ROM_TABLES
/* Save RAM by adjusting to our exact needs */
#define MBEDTLS_ECP_MAX_BITS 384
#define MBEDTLS_MPI_MAX_SIZE 256 // 2048 bits
/* Save RAM at the expense of speed, see ecp.h */
#define MBEDTLS_ECP_WINDOW_SIZE 2
#define MBEDTLS_ECP_FIXED_POINT_OPTIM 0
/* Significant speed benefit at the expense of some ROM */
#define MBEDTLS_ECP_NIST_OPTIM
* You should adjust this to the exact number of sources you're using: default
* is the "mbedtls_platform_entropy_poll" source, but you may want to add other ones.
* Minimum is 2 for the entropy test suite.
#define MBEDTLS_ENTROPY_MAX_SOURCES 2
/* Save ROM and a few bytes of RAM by specifying our own ciphersuite list */
#define MBEDTLS_SSL_CIPHERSUITES \
MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384
* Save RAM at the expense of interoperability: do this only if you control
* both ends of the connection! (See coments in "mbedtls/ssl.h".)
* The minimum size here depends on the certificate chain used as well as the
* typical size of records.
#define MBEDTLS_SSL_MAX_CONTENT_LEN 4096
#include "mbedtls/check_config.h"
#endif /* MBEDTLS_CONFIG_H */Any thoughts?
