SPI Driver for ESP8266 RTOS SDK
ritesh
Contact:
Postby ritesh » Thu Feb 16, 2017 9:19 pm
Hi All,
I am planning to use ESP8266 as SPI Slave Device which can be operated from some SPI Master Device based on functionalities. I have checked that there is SPI driver into ESP8266 NON OS SDK but there is no any source into ESP8266 RTOS SDK.
So, does anyone has any idea from where i can get SPI driver for ESP8266 RTOS SDK?
Regards,
Ritesh Prajapati
ritesh
Contact:
Re: SPI Driver for ESP8266 RTOS SDK
Postby ritesh » Fri Feb 17, 2017 12:02 pm
Does anyone has checked that ESP8266 can be worked as SPI Slave Device and it can be controlled from Master SPI Device? Does Espressif Systems has released SPI Master and Slave based driver into ESP8266 RTOS SDK?
If it is possible then please provide me sample example with SPI Driver for RTOS SDK.
Regards,
Ritesh Prajapati
ritesh
Contact:
Postby ritesh » Sat Feb 18, 2017 2:50 am
I have tried to search over Internet and found latest ESP8266 RTOS SDK in which spi_interface driver has been added in which that driver will work for both SPI Master and Slave mode asper driver source code
Please find below link for more information
https://github.com/espressif/ESP8266_RTOS_SDK?files=1
So, it seems like that will work as per my SPI Slave as ESP8266 requirement for my project.
I will check that on Monday and will update once will verify with SPI Master device..
Regards,
Ritesh Prajapati
Users browsing this forum: No registered users and 298 guests
